SC400 mode select/plenum not working
Old Apr 30, 2026 | 05:25 PM
mikebrinson's Avatar
mikebrinson
10th Gear
Default SC400 mode select/plenum not working
'95 SC400 plenum is not switching between modes. All the air is coming through the dash vents. I haven't driven the car in three weeks and I believe it was working prior to that. At any rate, it's not working now. I realize it could be due to either a vacuum leak or an electrical problem. I was hoping some of the members here might have some suggestions to help me narrow it down.
Old May 2, 2026 | 05:33 PM
RXRodger's Avatar
RXRodger
There is a door actuator most likely not switching.
Old May 3, 2026 | 11:22 AM
mikebrinson
10th Gear
No, both door locks and windows are functioning properly. I have yet to go through the various fuses to see it that could be the cause, but the fact that the display, the fan switch and the recirculation buttons respond correctly, I have my doubts that it is a fuse.
Old May 3, 2026 | 09:01 PM
RXRodger's Avatar
RXRodger
Sorry I was not descriptive enough. One of the blend door actuators in the hvac system is stuck, stripped,
or has lost power from the climate control unit. Or the climate control unit has an issue. Most likely the blend door.
jdub20tx
Aug 26, 2015 05:39 PM
KC95SC400
Aug 21, 2013 12:19 AM
Dispin
Aug 5, 2009 07:39 AM
Lextreme
Aug 5, 2005 08:49 AM
lexus4jess
GS - 1st Gen (1993-1997)
Jan 13, 2005 07:37 PM
