loose vacuums
Old Dec 27, 2024 | 07:48 AM
oldengineer's Avatar
oldengineer
Question loose vacuums
Does anyone know what this hose and this nipple are for? I don't feel any vacuum when I put my finger on them, at least not at idle. Do I need to close them off, or connect them to each other, or ignore them, or what? '95 SC300.
Old Dec 27, 2024 | 07:36 PM
KahnBB6's Avatar
KahnBB6
That vacuum hose area is for the Heater Control Valve assembly (HCV). The round cylindrical top thing next to it has a vacuum diaphragm inside which articulates a little metal arm underneath. The little metal arm is connected to the actual heater control valve which your coolant lines are connected to from the back of the engine above and to the heater core pipes in the engine bay firewall below.
The vacuum lines which are currently disconnected are part of the HCV Vacuum Switching Valve (VSV). This is an old 1980's-1990's method (sometimes still used on a few new cars today but now very seldom compared to older cars) of allowing the engine computer, or in this case with our SC300/400 the climate control computer in the dash center console, to open or close the vacuum in that area with that VSV so as to make the heater control vacuum diaphragm cause the heater valve to open fully, stay partly open or stay fully closed.
On the little VSV one vacuum nipple is specifically for vacuum going IN and one is specifically for the vacuum going OUT (to the HCV diaphragm module).
I can shoot you a picture from my SC's engine bay tomorrow to show how it's supposed to be connected if no one else beats me to it first.
Old Dec 28, 2024 | 07:20 AM
oldengineer
Thanks, that would be cool. As far as I can tell, the heating and cooling works normally including the automatic control, but unconnected connections are annoying.
Old Dec 30, 2024 | 07:26 AM
GAsc300's Avatar
GAsc300
In case you didn’t get another photo…
here’s screenshot of mine for references when I was taking it apart few years ago. I’ll bet your current vacuum line setup is allowing coolant flow into heater core at all times.
Old Dec 30, 2024 | 05:06 PM
oldengineer
Ok, I see. Someone put it together wrong at some time in the past. That's an easy correction, I'll do that in the morning. Thanks a bunch!
95lexus2jzge
Nov 28, 2023 04:51 AM
Golden95SC
Lexus Vehicles Classifieds
Nov 23, 2017 02:24 AM
TechGreek
SC400 / 300 Classifieds
May 15, 2011 04:01 PM
lvanlanen
Jun 8, 2008 08:49 AM
jburghardt
Feb 8, 2007 12:20 PM
