A fix to voltage drop and jumps?
Old Nov 29, 2024 | 06:11 PM
That1sc400's Avatar
That1sc400
Question A fix to voltage drop and jumps?
This SC has not stopped giving me problems with voltage drops, I have replaced my battery, my terminals, and my alternator, and still my voltage just drops and jumps around. Im stuck but what I really think is the belt tensioner is pretty bad and original and can be replaced. since it drives the accessory belt could that be the issue of my voltage jumping around? most of the main grounds were checked and its not those.
Old Nov 29, 2024 | 08:45 PM
SexCoupe's Avatar
SexCoupe
Did you check the alternator pigtail?
Old Nov 29, 2024 | 08:54 PM
That1sc400's Avatar
That1sc400
is that connected to alternator bc I can go check right now? should I wiggle it or unplug it?
Old Nov 29, 2024 | 09:06 PM
SexCoupe's Avatar
SexCoupe
yes unplug it check the wiring behind the plug. also check for corrosion on the power wire. there is a box next to the power steering pump mounted infront of the strut tower with clear glass on the top look inside for burns or corrosion. also check the ALT fusible link for corrosion
Old Nov 29, 2024 | 09:12 PM
That1sc400's Avatar
That1sc400
Okay thank you, not the fuse box correct, I'll check there too
Old Nov 29, 2024 | 09:13 PM
SexCoupe's Avatar
SexCoupe
yes the fusible link is in the fuse box
Old Nov 29, 2024 | 09:31 PM
That1sc400's Avatar
That1sc400
i'll update you tomorrow
Old Nov 30, 2024 | 07:58 AM
t2d2's Avatar
t2d2
Also check for bad grounds...loose connections, brittle wiring...anything that could be resulting in an intermittent ground signal.
Old Dec 13, 2024 | 05:12 PM
That1sc400's Avatar
That1sc400
problem is I don't know where most of the grounds are on this car. But there was this one ground near the left catalytic converter, I wiggled it and it just fell apart, but it did not affect anything on my SC. Should I be concerned?
Old Dec 14, 2024 | 07:43 AM
t2d2's Avatar
t2d2
For the most part, grounds are cumulative. The more connections to the frame, the better, and one bad one usually won't bring down the system. So, the one you found that crumbled was likely too far gone to contribute anything up to that point. That tells you nothing about the health of the rest of the system...
Nate99RX
RX - 1st Gen (1999-2003)
Mar 15, 2024 06:19 PM
dbk0003
Jan 5, 2021 07:57 PM
Grover01
May 13, 2011 07:47 PM
Bob'sSC400
May 17, 2008 09:43 AM
RaynArt
Jul 18, 2005 12:50 PM
