Gas. Flow. Problem
Old Nov 17, 2024 | 04:46 PM
Steph3235's Avatar
Steph3235
4th Gear
Default Gas. Flow. Problem
Having trouble. Gas. Is not. Flowing. To. Engine might. Be. Hose under fuel tank. Any suggestions on complete fix. To. Make. Gas. Flow. To. Engine
Old Nov 18, 2024 | 08:25 AM
Duck05's Avatar
Duck05
Investigate the Fuel Pump ECU…. Mine went out several months back….
Old Nov 18, 2024 | 08:31 PM
RXRodger's Avatar
RXRodger
As previous poster said make sure the fuel pump ecu is not the culprit if it’s still in the circuit and has not been bypassed. Next the fuel filter has always been a pain to change because the crimp nut will bottom out and sometimes almost gald the threads when trying to remove so they don’t get changed. I had a fuel pump inlet sock rip and clog the inlet one time, so there is always that possibility. Good luck finding the source.
Old Dec 2, 2024 | 07:04 AM
Steph3235's Avatar
Steph3235
4th Gear
Default Gas not getting to engine hose at bottom of fuel tank bent replacement with gas hose
Have 93 Sc 300 I. Replace battery alternator gas tank an fuel pump ECU work fine pipe at bottom of gas tank bent replaced it with gas rubber hose? Any suggestions won't start
wrinkle
Hybrid Technology
Apr 28, 2024 11:39 AM
ariescrown
Jan 10, 2024 02:35 PM
jcuddy428
IS - 1st Gen (2001-2005)
Nov 30, 2012 07:05 PM
NINEZeRO
Nov 9, 2008 11:14 PM
trischulte
RX - 1st Gen (1999-2003)
18
Apr 30, 2002 09:16 PM
