Idling weird, won't start
Old Oct 22, 2024 | 06:03 AM
TTurboVoltage's Avatar
TTurboVoltage
10th Gear
Default Idling weird, won't start
My 1995 SC300 won't start or idle correctly in the mornings,the car will idle at 800 RPM then jump up to 1200rpm or it will completely not idle at all. I checked to see if it was my ECU and there's no issue, but when I try to start my car at like 2:00 in the afternoon no issues. It is a little bit colder in the mornings but not extremely cold. Any ideas or advice on what could be causing these issues?
Old Oct 22, 2024 | 05:05 PM
Tallyhoe's Avatar
Tallyhoe
Most would say ECU capacitors have failed and causing issues.... I would say rebuild the idle speed control first, then move on to the ECU or possibly other electrical gremlins.
Old Oct 22, 2024 | 08:56 PM
RXRodger's Avatar
RXRodger
Check for air leaks in intake; hoses, connections, etc. Check IAC valve.
Check MAF
Check two wire temp sensor in head.
If you have one of the custom readers you can check temp reading, afr, etc and see if on cold start you see anything. I have one somewhere but have t used it in years.
Old Oct 23, 2024 | 11:11 AM
Christine93's Avatar
Christine93
3rd Gear
Default Stuck in park!
Hello, new here. But really need help. Im halfway between Tahoe and placerville and car is stuck in park. My windows and radio also don't work.
any ideas??
Old Oct 24, 2024 | 07:28 AM
Tallyhoe's Avatar
Tallyhoe
any ideas??
Stuck in Park as in unable to turn it on? Or it's refusing to release from Park? There should be an override button right by the shifter where you can use a flathead screwdriver and push it down. This will release the transmission from Park
Old Oct 26, 2024 | 01:46 PM
RXRodger's Avatar
RXRodger
any ideas??
as tallyho said just pop out the cover for the release and insert something to release the park lever. But it sounds like you have a power source issue. Check all the large fuses in the engine bay and in the left kick panel.
Ekul61
Nov 4, 2021 07:48 AM
Troels
Aug 28, 2021 04:57 AM
ISFFUN
Feb 27, 2014 01:54 PM
NEbiker10
Apr 10, 2011 11:10 AM
PsiQo1
Dec 1, 2006 12:10 PM
