1993 SC400 Crank no start
Old Apr 11, 2024 | 04:09 PM
benmarquis's Avatar
benmarquis
3rd Gear
Exclamation 1993 SC400 Crank no start
Hey i'm getting ready to buy a 93 sc 400 that is in a crank no start condition. I have another 93 sc400 sister car that I put back together a few years ago and is currently running perfectly at the moment. Also have a bunch of spare parts if needed to get the thing started. (ecu, fuel pump, starter, etc.)
Im pretty familiar with the platform so I know some basic checks on what to do/ look for. I was wondering if anyone else has ever had one in the same crank no start complaint and had any tips, tricks, or common problems. The previous owner has stated that they have tried "basic checks" like checking fuses and other little things here and there. He states that he thinks its an electrical issue, but the only electrical issue i can think of if it still cranks, would be a possible ecu/ maf sensor deal. I personally haven't ran into the ecu issue, but reading on these forums I have seen that there is a common problem with the ecus having leaky capacitors causing a wide variety of problems. I've heard that it is possible to send the ecus out to be re built if needed.
I
Just wondering if there is anyone out there that has had the same or similar issue that I am going to have. I appreciate any help or tips.
Old Apr 12, 2024 | 07:25 AM
SexCoupe's Avatar
SexCoupe
turn the key to the on position dont start and see if the CEL light is on. if it is then listen for the fuel pump to prime by ear. then pull codes using the jumper box E1 and TE1
Old Apr 13, 2024 | 01:18 PM
RXRodger's Avatar
RXRodger
Sounds like you know the likely suspects: fuel pump, fuel pump ecu, ECU fuse, ECU.
Do the easy stuff first, try the fuel pump ecu bypass. Check for fuel pressure at the rail.
Old Apr 15, 2024 | 03:06 PM
benmarquis's Avatar
benmarquis
3rd Gear
Hey thank you @RXRodger and @SexCoupe for the replies.
I have done some checked like checking the fuel pump. I heard it audibly prime while the key was turned on. Weird thing was that the CEL light was not on. Did some other electrical checks and found out that it dialed down to the bad ECU. Thankfully I had an extra good one sitting in my storage unit. Plugged it in and it fired right up. (got very lucky with that).
Thank you guys for the input and help. Just curious if you guys/ anyone else would know where to send those ECU's out to get rebuilt if needed. may or may do that with this one, but none the less I am curious if there is any place to ship/take them too if needed. Again thanks for the tips/tricks.
SnotRocket2
Jan 8, 2024 10:19 AM
Aniyah87
Jul 16, 2018 01:59 PM
loebco
Jul 16, 2017 06:35 AM
Gooshey
Feb 9, 2014 02:48 PM
