Leaking brake hose
Old May 25, 2023 | 07:02 PM
pishta's Avatar
pishta
Default Leaking brake hose
1992 SC400.....Does anyone have a part number or name for the hose that goes from the driver side ABS accumulator to the pump? I think that's what the 2 parts are. It has a banjo fitting on both ends and a rubber mid section. It's line in the pic. . It dumps brake fluid only when the pump is running on startup. you can see the wet part under the crimp.
Leaking brake hose down side of accumulator/pump?
ic .
Old May 25, 2023 | 07:08 PM
pishta's Avatar
pishta
better pic, its the J shaped hard/soft line
Old May 28, 2023 | 08:05 AM
pishta's Avatar
pishta
44510A
90947-06006 Hose, Pressure Discontinued
So what the heck do I do, get one made by a hydraulic hose shop or make it a hard line and solder a brake line to the stubs? As far as I can tell, the only reason this is a soft line is to isolate vibration from the pump motor while its running from the accumulator? I can make it a hard line easily but the momentary buzzing to charge the accumulator will not be "Lexus".....
Old May 29, 2023 | 08:03 AM
pishta's Avatar
pishta
found part number but no one stocks it,
HOSE, PRESSURE
Part Number: 9094706006
Supersession(s): 90947-06006
So its a soft brake line and Lexus doesn't stock it anymore. WTF?
Old May 29, 2023 | 09:46 AM
Tallyhoe's Avatar
Tallyhoe
This may be one of those rebuild items. If not maybe a replacement, like a brake line that would fit, both fittings? The power steering hose is discontinued on the 400 and am picked up a direct fit pressure hose from Drift motion...
Old May 30, 2023 | 07:37 AM
pishta's Avatar
pishta
looks like 2 10mm banjos and a maybe 300mm total length. I think I can get one made by a hydraulic hose place.
Old May 30, 2023 | 10:04 AM
RudysSC's Avatar
RudysSC
^ A good hose shop should most definitely be able to help you out!
desmo907
Hybrid Technology
Feb 23, 2022 12:20 PM
darimura
Apr 1, 2013 11:11 PM
tranft
Suspension and Brakes
May 19, 2006 09:57 PM
