Manual Swapped, Dies When Clutched
Can try cleaning the IACV but don't think it does much when the engine is warm and at idle.
I'll try and find a part number.
edit - I found one (not sure if actually in stock) hopefully you don't have to resort to this but it does work
https://toyotaparts.lakelandtoyota.c...ody-2220235271
here is another version
https://www.toyotapartsdeal.com/oem/...202-62190.html
Edit: As I'm looking at this picture I realize how easy it would be to just adjust the pedal/throttle cable to idle higher. Good idea?
Making a custom bracket for one of those dampers would not be super hard. Hard part is finding one.
Out of curiosity, what are the RPM"s at 65MPH? How about at 80MPH?
I monitor battery voltage and I can see it drop below 12, which causes the entire engine to die. But on manual cars if I let off the clutch the engine immediately restarts and its like nothing happened at all. It's a bit different with coasting auto cars, you can put them back in gear but they don't always restart themselves
Once i turn it back on i could coast in neutral just fine.
I usually have to play with the throttle to hold the revs up so it doesn’t die when i push the clutch in.
Usually if i do it correctly, the car gets very close to dying but i catch it by pushing the throttle and thus keeping the engine alive.
It’s almost as the revs drop quicker than what the IACV can calculate. Which is why i need to give it gas to it can hold idle for me…
The dashpot idea seems like it could mitigate this issue, but i’m just curious as to how it was installed or if it fixed the issue completely. hmmmm….
