HomeLink not learning gate code
Old Feb 11, 2023 | 02:41 PM
CCTX's Avatar
CCTX
Default HomeLink not learning gate code
I was able to program my RX HomeLink for my garage door with no problem. However, for some reason, it can’t learn (as in reading the code) of my community gate remote. It is a Linear MT-1B remote (318 MHZ). I followed the instructions in the manual, searched online…etc. but nothing worked. This same remote worked just fine with HomeLink in my other cars with no problems. I also called the 800 number for HomeLink but couldn’t get to speak to a human. Any help will be greatly appreciated.
Old Feb 12, 2023 | 08:40 PM
PeteInGilr's Avatar
PeteInGilr
I had that same problem in previous vehicles. I think the issue is if the remote has specific number codes (open the back cover), then I could never get it to work.
Old Feb 13, 2023 | 09:48 AM
Eagleboy99's Avatar
Eagleboy99
Moore-o-matic MegaCode is proprietary 1,000,000 codes. I've used Hoermann before with HomeLink (weird EU frequency) so anything is possible. Have you looked at https://bridge.liftmaster.com/#/sele...e-instructions
Old Feb 13, 2023 | 12:39 PM
CCTX's Avatar
CCTX
Thanks! Unfortunately, it doesn't work still. Will try HomeLink CS again.
Old Feb 13, 2023 | 01:41 PM
Eagleboy99's Avatar
Eagleboy99
One other thing to check is the batteries in your gate remote. If they are low, they may not have enough power to fully transmit the code.
Old Feb 13, 2023 | 01:50 PM
CCTX's Avatar
CCTX
That is true but I actually tired a fresh battery and it didn't work.
Old Feb 14, 2023 | 08:49 AM
offroad200's Avatar
offroad200
Most neighborhood/commercial gates only transmit a very short signal. So when you push and hold the gate remote, it stops transmitting after a few seconds. Try this, when the mirror is blinking orange, push and hold the gate remote for a few seconds then release. Repeat this until Homelink blinks green. Sometimes it helps to be parked in front of the gate as well.
Old Feb 14, 2023 | 06:43 PM
CCTX's Avatar
CCTX
it WORKED!!! Thank you so much. This was most helpful.
Old Aug 1, 2023 | 10:19 PM
ParkCityLexus's Avatar
ParkCityLexus
3rd Gear
Question Programming Homelink Digital Mirror
I've probably programmed Homelink with a "rolling code" garage door opener in 10 vehicles, but my 2023 350h has me stumped. I even resorted to reading the manual... Still nothing. I have a digital rearview mirror which may program differently than non-digital. I push the link button on my garage door drive housing and immediately follow the steps in the manual. Nothing. Does anyone know the secret?
Old Aug 2, 2023 | 04:48 AM
Carbuff2's Avatar
Carbuff2
The digital mirror's Homelink isn't any different from analogue mirrors.
The only thing I can think of is the time-limit for programming after you press LEARN on the drive housing.
On our European car it took several tries to fall off the ladder and work the car's buttons in time.
Old Aug 2, 2023 | 05:31 AM
Malky's Avatar
Malky
I made this mistake too ... My previous vehicles, with homelink, required pressing the learn button on the garage opener housing (my garage door opener is also rolling code). With the lexus system it learns with the remote, don't need to hit the learn button.
Old Aug 2, 2023 | 06:57 PM
Deeps1's Avatar
Deeps1
this is the best method. programmed it yesterday. infact the mirror itself provided ste by step instructions.
Old Aug 2, 2023 | 08:24 PM
BerthoudPa's Avatar
BerthoudPa
I needed to READ the garage door opener book very carefully. A couple of times. Genie had to use the learn button.
Old Mar 24, 2024 | 11:26 AM
Bulldog50's Avatar
Bulldog50
Default Homelink
My Homelink Transmitter button on the mirror on my RX 500H is very weak. I have to be almost on top of my garage door for it to work. My BMW Homelink button works fine, even all the way down the block, so I think the problem is specific to the RX. Is there anyway to make the RX mirror button more powerful? As I said the BMW button for the same garage door works way better. Thanks for any help.
Old Mar 24, 2024 | 01:02 PM
Carbuff2's Avatar
Carbuff2
Interesting...our RX (and our European car) have a nice long Homelink range...longer than the actual garage-opener remotes that are in our other two sports cars.
