2 Inch trailer hitch questions
#228
We waited forever for the hitch to come in, took it to the dealer and dropped it off and this was how it came back, scratched to hell and with some sort of foam gasket around the cutout. Has anyone else had the OEM hitch installed by a dealer and did it come back mangled like this? This can't possibly be how Lexus intended for it to be installed.
#229
My Lexus OEM hitch was factory/port installed.
There are a lot of scratches on your bumper and what looks to be a used Lexus rubber hitch cover. Are you saying the dealer made all those scratches on the black bumper trim piece?
I believe the lower black trim of the bumper should have been removed and replaced with the one designed with the hitch cutout. Did they mention there is a bumper trim piece when installing a hitch? I am not sure if that black trim piece with the cutout is available separately or if the entire bumper cover needs to be replaced which involves painting as well.
All things considered, the cutout they did for your install does not look that bad compared to other installs I have seen. However, the dealer should have done a better job informing you of what their installation entails compared to the standard offered by Lexus. Given the scratches, most likely from them removing the trim piece and reinstalling, I would get them to replace with the trim piece made for the hitch.
#231
Yeah they scratched up the plastic while they were at it. There apparently isn't a replacement trim piece in the kit, the black part of the bumper needs to be cut, there is supposed to be a relief that you follow as a template. I don't think the hitch cover is used, I think it is just the lighting, but now that you say it I'll go take a closer look at it.
I also went back and measured it because it didn't look centered, and sure enough the cutout isn't centered and the foam is already coming off in once section.
I did talk to the manager while I was there, he's going to call me back tomorrow, he said he's going to talk to the tech. Worst case scenario I'll just fix it myself, but I just feel like this foam can't be Lexus's intended install.
Urlik (05-15-24)
#232
There is a replacement part with integrated cutout. Your dealer messed up the cut and scratched that part. I would ask them to replace that part with a new part with the cutout.
Their hitch installation instructions for USA will have the part number on it.
#234
They are replacing the whole trim piece, it seems that adding the foam wasn't in the instructions or anything like that, the Tech was just "trying to add a beauty trim and used that foam because he thought it was missing from the kit". They are making it right, that is what matters so I'm happy.
#238
I have had a hitch on my last two RX's and current 2024 RX 350h. All three have been Curt. I just had my Lexus dealership install it $180 and I bought it on line for $220. I was concerned with the looks of it. Did not want it sticking out or looking to obvious. Very pleased. Bike rack holds two bikes. Does not interfere with the kick sensor.
Ascho (05-23-24)
99mcg
RX - 3rd Gen (2010-2015)
04-07-14 12:24 PM
