Upgrading stock ML subwoofer?
Old Apr 3, 2025 | 07:10 PM
Jasaveli's Avatar
Jasaveli
Default Upgrading stock ML subwoofer?
Has anyone upgraded the subwoofer or added in a powered under seat subwoofer to the ML system?
Old Apr 5, 2025 | 01:25 PM
AlmostJake's Avatar
AlmostJake
I did that in my 2019 Hybrid Highlander. It was easy and can't be much different.
As for the Lexus. Before you start replacing; try adding sound deadener behind the sub to see if that helps enough to where you can tolerate it. Also add some insulation behind the sub to filter out any reflections that may muddy the sound. If you're still unhappy, replace the sub, but find the highest efficiency sub you can fit, to get the most out of the existing amp. IF you still want more, then add an dedicated amp for the sub.
Keep in mind that the above work won't go to waste; it will help the new setup sound better.
Old Apr 5, 2025 | 05:55 PM
Urlik's Avatar
Urlik
I wish there was a way to add a couple woofers. AlmostJake’s post is awesome though, might try some sound dead ear to see if it helps.
Old Apr 6, 2025 | 05:31 AM
Carbuff2's Avatar
Carbuff2
My ears are 'dead' from participating in rock bands in high school!
<<< I know, it was a typo >>
LS500Fan
ES - 7th Gen (2019-2025)
Jun 3, 2022 07:06 PM
Is200tieu
RC - 1st Gen (2015-present)
Sep 15, 2021 11:31 PM
Supermuku
Mar 12, 2014 07:06 PM
Eddie80
Mar 2, 2006 11:31 AM
