Ceramic Coating
Old Nov 19, 2024 | 07:42 AM
rmgmag's Avatar
rmgmag
Default Ceramic Coating
Have an appointment Thursday to get my new RX350 ceramic coated. Predicting a high of 40 degrees. Is that too cold to have it done? Worried about application and curing time when it’s that cold.
Old Nov 19, 2024 | 08:16 AM
Acceptable temperature range depends on the particular product used, having said that 40 degrees sounds too cold for any of them to cure properly.
Old Nov 19, 2024 | 01:43 PM
lexusnyca's Avatar
lexusnyca
Don't they apply it indoors?
Old Nov 20, 2024 | 03:33 AM
paperthin's Avatar
paperthin
Isn't there directions on the bottle?
Old Nov 20, 2024 | 07:12 AM
Chris442's Avatar
Chris442
Veteran: Marine Corps
It must be applied in a climate controlled, clean environment. If it is being applied by a reputable business then they should be following these guidelines.
Old Nov 20, 2024 | 09:54 AM
The potential issue is after application, depending on the coating it can take 7 days for it to fully cure and that's at 60+ degrees.
Old Nov 26, 2024 | 06:21 PM
Chuckinnj's Avatar
Chuckinnj
"IF" the detailing shop doesn’t have a climate controlled inside environment at 60*F+ for applying a ceramic coating, I suggest that you run away and find another shop.
Jakerin
Dec 29, 2022 04:13 PM
sj408
Jul 28, 2015 12:01 PM
blackie76
GS - 1st Gen (1993-1997)
Mar 5, 2012 09:01 PM
runningox
Jan 12, 2009 03:40 PM
daryll40
Jan 24, 2005 06:55 PM
