Hard to shift from reverse to drive
Old Oct 15, 2024 | 05:28 PM
grhughes's Avatar
grhughes
Default Hard to shift from reverse to drive
I put the car in reverse to back out of the drive. Get to the end of the drive and it will not shift into drive unless I press like hell on the brake pedal. I've never in my life had a car that I have to stop completely to shift into drive. Am I the only one with this issue? Today I was making a "quick" three point turn and boy was that a fiasco. There has to be a fix for this as it's going to get me killed.
Old Oct 15, 2024 | 06:57 PM
chuckNX's Avatar
chuckNX
Dealer, sounds like the brake interlock switch needs to be adjusted or replaced.
Old Oct 16, 2024 | 07:26 AM
toyotaman7's Avatar
toyotaman7
Knowing that shifting into reverse while the car is still moving in opposite direction will damage the transmission, I've never attempted doing that with my cars.
I would not be surprised that Lexus programmed it to see the speed = 0 before allowing shifting to opposite direction.
I know that I can shift from neutral to drive while the car is moving forward without stopping since i accidentally touched the joystick and went to neutral while driving. I just shifted back to drive quickly.
Old Oct 16, 2024 | 10:33 AM
Carbuff2's Avatar
Carbuff2
Perhaps there is something 'funky' about how the OP's shifter is sensed, left-to-right.
The shift lever has to be pressed LEFT to shift or change selections doesn't it?
Our European car requires a trigger squeeze instead of L<->R movement. Occasionally I'll do the wrong thing in either car, LOL,
Old Oct 16, 2024 | 04:48 PM
kry226's Avatar
kry226
I've experienced this countless times... and it has nothing to do with "shifting on the move." Pressing harder on the brake pedal is always the answer, and I know because the midi always tells me to press the brake... which I'm already doing. And frankly, it's a not-so-great answer.
Old Oct 16, 2024 | 04:52 PM
mikemu30's Avatar
mikemu30
That would typically show signs shifting out of P.
Old Oct 16, 2024 | 11:40 PM
Nevada's Avatar
Nevada
I have had that complaint from a customer and did verify the operation. There is a brake pedal pressure sensor in the brake system, the driver must press the brake pedal with enough force that will ensure the vehicle will not move (while on a hill) before the computer will respond to gear shift lever inputs.
You can verify this: shift from drive-to-reverse, reverse-to-drive a few times, now ease up on the brake pedal just to the point where the vehicle won't roll away and try the shift lever. It will not respond.
GS4_Fiend
RX - 4th Gen (2016-2022)
19
Aug 26, 2022 08:52 PM
mvaldez24
May 31, 2018 01:53 PM
loccsta187
Jun 28, 2011 01:53 PM
funcrusher
Mar 25, 2011 07:30 AM
hung8852
Dec 11, 2006 03:30 PM
