S Flow Question
Old Oct 1, 2024 | 03:19 PM
tlaspec1's Avatar
tlaspec1
Default S Flow Question
Wondering what everyone's experience is with S-flow function under climate. Reading the manual it suggests that S flow directs air only the areas where there are occupants since the car can sense front passenger via weight sensor and rear passengers via door opening and seatbelt usage. On my 24 350h S flow works fine for front passengers; however, the rear vents never seems to come on unless someone presses the rear climate buttons which disables S flow, not sure if this is intent of design or something is wrong with my car. I would of expected S flow to work automatically as the car's rear seat reminder works fine.
Old Oct 1, 2024 | 06:30 PM
Drumr13's Avatar
Drumr13
I'm with you. Always have to turn it off to get air in the back. Seemed to work originally and now not so much and both kids use seatbelts so the car knows someone is there! Can it be disabled permanently? (Didn't read up in manual yet)
Old Oct 1, 2024 | 06:52 PM
tlaspec1's Avatar
tlaspec1
I have disabled S flow and manually set a temp for the rear. The S flow does not come back on.
Old Oct 1, 2024 | 06:54 PM
Drumr13's Avatar
Drumr13
I'll try that, thought I had them setup to sync, but doesn't hurt to verify!
Old Oct 1, 2024 | 07:03 PM
Urlik's Avatar
Urlik
I live in the south and S-flow keeps the cabin from cooling off as quick as it could. Turned it off shortly after buying and won’t turn it back on.
Old Oct 1, 2024 | 07:41 PM
Drumr13's Avatar
Drumr13
would rather keep it off.... couldn't figure out a way to keep it that way without turning it off each time manually
fieldrt
NX - 2nd Gen (2022-current)
May 31, 2023 11:34 AM
Casares
UX Models (2019-present)
Jul 28, 2021 04:58 AM
PsychoFish
RX - 3rd Gen (2010-2015)
Jul 11, 2016 07:10 PM
stl2chi
GX - 1st Gen (2003-2009)
Mar 7, 2007 06:55 AM
Rob L
Feb 1, 2002 07:16 AM
