Dead 12v battery Incident (merged threads)
Old Jun 8, 2024 | 10:48 AM
  #421
Urlik's Avatar
Urlik
Originally Posted by wrinkle
I was initially settling on the AGM Walmart sells, because its cheap at $180 and also has 4 year replacement warranty serviceable at any Walmart. However, on looking closer I found that it has two "venting" ports that can release occasional gas from the chemistry - which makes that particular AGM a problem for the NX/RX batteries that are sitting in the passenger cabin. However, the Odyssey AGMs are fully sealed and do not have those vents.
How is Lexus venting the current lead acid?
Old Jun 8, 2024 | 11:06 AM
  #422
WellsB's Avatar
WellsB
I simply can't imagine being able to notice a fuel economy hit from using an AGM battery. We're talking miniscule power requirements, in comparison to actually moving the vehicle.
Just to be clear, Odyssey documents talk about recovery from deep discharge sometimes requiring much higher amperages than regular chargers can supply, combined with a requirement that voltage not go too high while providing those amperages. There is a very short list of chargers that can do that.
It has a vent hose to the exterior.
Old Jun 9, 2024 | 08:50 AM
  #423
StefanoS's Avatar
StefanoS
Originally Posted by WellsB
My observations of the charging behavior of the RX450h+ lead me to believe that it is time-based. It seems to have no concern for battery charge state. There is an initial 14v charging cycle while driving, but then it drops to a low float-voltage, around 12.8, at most times. The primary exception is when the vehicle is in Ready mode and in park. At that time, the voltage stays above 14.
I did observe the charging system stay above 14 volts for about 30 minutes, while driving. I believe this is a time-based maintenance cycle. In 3 weeks of driving, I've only seen it happen once. The battery was not at a low state of charge when it occurred.
I am seeing essentially the same thing with my two 450h+ models. The voltage in READY mode is consistently at 14.1 to 14.2v (and on rare occasion, I've seen 14.4v) but, as soon as I start to drive, it soon drops to 12.5 to 12.6v unless the resting SOC was lower than normal. Like WellsB, I have started doing a trickle charge on each battery more often than once monthly, like every ten days or so.
Old Jun 9, 2024 | 11:46 AM
  #424
websurfer's Avatar
websurfer
I have been reading this thread over 2 days already (long thread). Lots of great ideas and info. Appreciate all the effort in solving the issue.
Has anything from Lexus or dealer tech mentioned anything on a solution?
I have trickle charge my NX once it's getting lower 12V lately also before reading this thread.
Today I did a test and it showed around 12.02 V and drove it for a few minutes today and measured the voltage back to 12.5V.
Old Jun 9, 2024 | 12:14 PM
  #425
jahnjva's Avatar
jahnjva
Has anyone measured their voltage in accessory mode prior to starting the car (after sitting all night)? I charged my 350h about 2-3 weeks ago. It measures 11.8v prior to starting. Then goes up above 14v once the car starts and then 12-13v while driving. Is 11.8v or lower considered ok or should it be replaced? I never had any issues starting the car and is about 1.25 years old. I plan to charge it every 1-2 months. I think I would have serious reservations buying a 450h+ knowing how much more of an issue its battery problems are compared to the other models. It amazes me how Lexus is so complacent fixing this given how long the NX450h+ has been out and having similar problems.
Old Jun 9, 2024 | 01:08 PM
  #426
BerthoudPa's Avatar
BerthoudPa
All I can say is what a hassle. I wouldn't do it
Push button go. buy new battery in 4 years, Rinse repeat,
Old Jun 9, 2024 | 01:13 PM
  #427
Ganoush's Avatar
Ganoush
3rd Gear
Can anyone who has been following more closely summarize this thread so far? Would like to catch up as a potential 350h buyer since this seems to be a pretty serious problem but I don't have a full day to read all 250 comments.
A lot of discussion about trickle charging as a solution, is this really what I am committing to if I buy this car...? I have to constantly babysit the battery every week?
Old Jun 9, 2024 | 06:09 PM
  #428
Overburn's Avatar
Overburn
5th Gear
Don't know if it's all cars. Mine lasted about a year before crapping out. Not impressed to say the least. Now I carry a portable battery booster and some booster cables at all times. Also trying to convince Lexus Canada to install the trickle charger port at their cost.
Bought a Lexus for that peace of mind but now I'm constantly worried about coming to a car with a dead battery.
Old Jun 9, 2024 | 07:34 PM
  #429
jahnjva's Avatar
jahnjva
Ganoush,
I have had my 350h for 1 &1/4 years and so far have not been stranded or had any dead battery problems. I think this problem is much more prevalent on the 450h+ Because of this forum, I just started charging every 1-2 months and carry a portable charger which has not been needed. I think if you use you vehicle daily or a few times a week and you trips are not just around the corner, you would be fine. If the car sits for 1-2 weeks and only goes short distances, then you might need to charge it some.
Old Jun 9, 2024 | 08:08 PM
  #430
Overburn's Avatar
Overburn
5th Gear
Originally Posted by jahnjva
Ganoush,
There doesn't seem to be a correlation between less use and this issue popping up. Read the thread and you will see this to be true.
On my 350h it is used almost every day for at least 100km/day. In fact when my battery died it was driven the day before, went to start it up in the morning and it was dead. Had to manually open the door with the physical key.
Old Jun 9, 2024 | 09:15 PM
  #431
jahnjva's Avatar
jahnjva
Overburn, I was commenting on my car experience. Also since the 12 volt will only charge when the car is turned on, the more it just sits, the less time the traction battery has to charge it. Lots of other facts can effect battery performance. (temperature out side, accessory mode use etc.) Lexus definitely has a battery issue most commonly on the 450h+ and to a lesser extent in its other models. Watch the video below, he talks about short trips and the effect on battery performance.
Old Jun 9, 2024 | 10:33 PM
  #432
wrinkle's Avatar
wrinkle
More data and information to help you make up your mind
Old Jun 10, 2024 | 09:10 PM
  #433
WellsB's Avatar
WellsB
Yeah, I've seen ours drop to 11.8 right after hitting the start button. Accessory mode will rapidly pull it below that.
For comparison, my Ford Focus pulls the voltage down to around 10.8 volts when engaging the starter.
Old Jun 10, 2024 | 09:26 PM
  #434
wrinkle's Avatar
wrinkle
Is the stock Panasonic battery that comes with the 450H+ any way different from a run-of-the-mill flooded Lead-Acid battery in terms of deep-discharge voltages it can sustain without damage ? Did Lexus source it from Panasonic with the particular risk of deep discharge in mind for these new RX/NX models?
I'm trying to decide if I should even ask for a new battery if the dealer finds it to be only slightly or not degraded at my 6 month service. The reason being, the run-of-the-mill Interstate 12 V that the dealer would replace it may actually be worse for the Lexus, given its deficient 12 V charging problem. There are at least anecdotal reports of folks having battery deaths even with new battery replacements - presumably due to their parasitic drain being high. In my specific case, I don't think my parasitic drain is very high (since it survived a 26 day parking without problem) - just the overall deficient charging design is the problem.
Old Jun 10, 2024 | 10:29 PM
  #435
WellsB's Avatar
WellsB
It's quite possible that the OEM battery is a deep cycle battery, considering that most batteries of similar size have 600-700 cca, vs the 345 cca claimed for the OEM battery.
Mine has been deeply discharged twice, and still shows very little wear on the tester.
