Dead Battery
On one cold day back in December I was gearing up for my morning dive. Because it was pitch black outside I thought it would be a good idea to leave the lights on (come/leave home stays on until the car is locked). The lights were on for about 40 minutes. I then locked the car (RX500h). Hazards flashed, buzzer beeped. I came back an hour later and popped the hatch open. The car beeped again and hazards flashed. And this is where the problems began. I tried opening the side door but to no avail (gotta thank Lexus for those idiotic electronic release handles). Pressing the unlock button on the fob only resulted in flashing lights but no buzzing. Doors were still locked. I had to climb over the back seats to reach the rear door manual release handle. Once the doors were open I tried starting up the car. It beeped again but the dash didn't even light up. Dead battery symptoms... Luckily another diver was parked nearby and had jumper cables. We jumped the battery and the car started right up.
Two weeks went by with zero issues.
Having feared being left alone with a dead battery in the middle of nowhere, I decided that my wife's husband deserves another Christmas gift in a form of a booster.
Sure enough, couple of days ago I had the same issue. No lights were running before locking the car but same symptoms came up again. The hatch opened no problem but then the car died on me again. The booster was put to its intended use and voila the car was brought back to life.
I blame the battery but wondering if this happened to anyone else. The car is less than a year old and Lexus keeps scoring top three across all known reliability charts. My next servicing is coming up soon so I will definitely have them look into it but my guess is that they will offer a battery replacement at my own expense.
Kinda ironic that a hybrid car is immobilized because of a dead battery.
First turn of the physical key unlocks the driver's side. Turn it again and it will unlock the other doors. Assuming you have battery, of course. If not, then I'd think you're left with pulling the physical lever on the inside of each door. One pull activates the lever as mechanical, 2nd pull unlatches. Got to agree with the "why" is this necessary, tho'. I know it's for the "active assist" so you don't open the doors into on-coming traffic. But, yeah, what was wrong with door levers we knew worked? I'd think these "safety features" could have still been implemented on standard door levers. My muscle memory still misses the real handles.
Klamalama (01-18-24)
How long did it take them to get to you? I suppose they don't have a dedicated mobile mechanic and just call first available contractor.
It took about 35 minutes from making the call and the tow truck arriving, so I was quite pleased in that regard. I also have BCAA(AAA) and it was the same company that responded on behalf of Lexus. Cheers
The following 2 users liked this post by CCGS:
BeamerDude (02-08-24),
tecdivingaccountant (01-17-24)
I agree, we have been members for 20+ years and have used them on a few occasion's. If it was up to me personally I would cancel it and save a few $.
Had the dead battery issue happen to me too after sitting in the car listening to the radio for about 20 minutes. Car was in ACC mode. The 12V batteries in these cars have a very minimal reserve. That said, I was already inside the car so I was able to double pull on the lever to open the door. Fortunately for me, I was able to open the rear hatch because I was storing my booster with the spare tire. Lesson learned, that booster is now stored behind the rear seat for easy access!
(here is how my incident went https://www.clublexus.com/forums/hyb...sory-mode.html )
The following 5 users liked this post by winpakbob:
BerthoudPa (01-19-24),
Carbuff2 (01-19-24),
CCGS (01-21-24),
tecdivingaccountant (01-19-24)
I read about AGM (Absorbed Glass Mat) battery which are supposed to last longer than lead battery. Is AGM battery compatible with the alternator in the RX 350 2023?
I think it's crazy that a new car battery can't support a 1/2 hour on accessory mode. Are these batteries very undersized or are they defective? I just put my portable charger (which I have never previously needed) in the car. I hope I never have to use it.
CCGS (01-21-24)
I ran down my daughter's battery while detailing her car before terminating her lease. That NEVER happened in the days of AM radios with ONE speaker!!! LOL
The following 2 users liked this post by Carbuff2:
autotech13 (01-20-24),
CCGS (01-21-24)
They handle the heat better. Turbos are tough on batteries since they tend to sit close to them. They also like to be charged at a slightly higher voltage than lead acid for maximum life. I wonder if there is a way to program the car for the type of battery. I put one in my VW and was able to program the car with my VAG com tool that I switched it to AGM (fleece in German). Hybrid folks have it the best with the 12V sitting in the rear. Those batteries should last at least twice as long as ones under the hood.
husky1055 (01-19-24)
AGM battery
I plan to ask my Lexus dealer to install a AGM battery in my RX350. If they agree to do it then they probably will adjust the alternator charger in my car so it will be compatible with the AGM battery.
I thought the AGM battery profile was primarily that it tolerated periodic short charge on/off cycles, which allows a clutch based alternator to be used to increase MPG. A lead acid battery needs a constant 13.5+V polarity to keep it charged.
