Touch Free Rear Door Issues
Old 09-22-17, 07:03 AM
  #136
FastFord
FastFord's Avatar
I asked about water leakage and the SA told me there is a seal behind the badge....how tight, don't know. There are no issues with the paint being marred or scratched. ...at least with mine. It slides pretty easily. So yes, floats above it is a good description.
JSracer (09-22-17)
Old 10-03-17, 09:06 AM
  #137
TeKKieNYC
TeKKieNYC's Avatar
Old 10-03-17, 11:46 AM
  #138
ericsan13
ericsan13's Avatar
Originally Posted by TeKKieNYC
Video
He forgot to mention that you need to have the doors unlocked to use the inside trunk open button. This confuses a lot of people too.
Old 10-04-17, 05:55 AM
  #139
FastFord
FastFord's Avatar
I was at the dealer to have my Touch free door opening emblem badge..whatever it's called replaced as mine was very loose. As it turns out the wrong part came in....Apparently there are two kinds, depending on something???
So the technician just added an extra seal and fitted it a little better than from the factory. The badge is nice and snug now, no side to side issues.
By the way you would never guess what the hands free touch badge costs...$800 Canadian as per the SA. Unbelievable...
Old 10-04-17, 05:14 PM
  #140
Nail34
Nail34's Avatar
Originally Posted by LCTMadison
When your hands are full, it makes it harder to push the latch. Being able to touch the emblem with your elbow to open without having to put stuff down to free your hands is great.
I wouldn't want to be able to open with the key fob in car....safety would be my concern.
My emblem is tight, does not move at all. I would take that to Lexus to get it fixed.
I repeat, I have never had the need to use my elbow however if I did I would wonder how I ever got along without the elbow or kick maneuver.
Re safety concerns, you can only open the hatch with the key in your pocket however if you use the latch you don't need the key fob at all, am I missing something here??
Old 10-04-17, 05:19 PM
  #141
toyotaman7
toyotaman7's Avatar
Not sure if you are asking a question or making a statement here?
Old 10-04-17, 06:06 PM
  #142
mikemu30
mikemu30's Avatar
Received 2,383 Likes on 1,712 Posts
in theory, you can't use the latch if your arms are full. Yes you are missing the point.
Old 10-05-17, 06:06 AM
  #143
Nail34
Nail34's Avatar
I am guessing that Lexus did not want the hatch to open when the fob is in the car because there could be an electrical malfunction and the hatch could pop open while driving.
Old 10-05-17, 06:13 AM
  #144
FastFord
FastFord's Avatar
My only worry with this whole hatch set-up is waiting for the day when it decides to open up on it's own/fob issue/user issue/etc, with the garage door closed!
Old 10-05-17, 06:32 AM
  #145
Nail34
Nail34's Avatar
Neither am I. LOL
Old 11-30-17, 08:55 AM
  #146
1111GS
1111GS's Avatar
I see many that can't utilize the feature. Does anyone know how to check that the feature is turned on? I'm looking at p101 and it says PBD needs to be turned on under system settings. I went into the vehicle setting/other vehicle settings but only see two things there: Driver Exit and Open position adjustment. Where do you go to check if PBD is all turned on? Thanks.
Old 11-30-17, 09:10 AM
  #147
Kiboater
Kiboater's Avatar
■ Vehicle settings
Item Settings Details
PBD (Power back door) (P. 130)
The following power back door settings can be changed:
System settings
All On Select to enable the power back door
system.
Touchless Sensor
Off (if equipped)
Select to disable the touchless sensor.
(Other power back door functions
remain enabled.)
All Off Select to disable the power back door
system.
Select to set the open position at
which the power back door will stop
when opened automatically.
Volume
3 (Loud)
Select to set the volume of the buzzer
which sounds when the power back
door is operated.
2 (Medium)
1 (Low)
TPMS (Tire pressure warning system) (P. 585)
Tire pressure warning system initialization
Select to initialize the Tire pressure
warning system. To perform initialization,
press and hold the
switch.
Before
File Type: pdf
Old 11-30-17, 11:53 AM
  #148
Jiggz858
Jiggz858's Avatar
One thing he missed to explain also is that if you double tap the "Close" PBD switch not only does it closes the PBD but also locks the vehicle at the same time.
Old 11-30-17, 01:38 PM
  #149
1111GS
1111GS's Avatar
Originally Posted by Kiboater
■ Vehicle settings
System settings
system.
Touchless Sensor
Off (if equipped)
remain enabled.)
system.
Volume
3 (Loud)
door is operated.
2 (Medium)
1 (Low)
press and hold the
switch.
Before
Yep that's what I see on P101 manual. But I didn't see what they were talking about. I just answered my question myself. Thanks TekKie for posting the video. I was setting on the big display. When you change setting like the guy does, it's the same like the manual talks about but not if you do on the big screen. Interesting.
Old 12-01-17, 09:57 AM
  #150
ravenuer
ravenuer's Avatar
Why thanks! I've been standing there waiting for the PBD to close and lock, then I'd lock the rest of the doors!
Quick Reply: Touch Free Rear Door Issues
