Roof Load
Old Aug 23, 2022 | 06:52 AM
regor60's Avatar
regor60
Default Roof Load
We have a 2020 RX with just the streamlined bars either side along the length of the vehicle, no cross members.
Is it OK to put luggage on the roof bearing directly on the surface?
Will be using a cargo bag strapped through the rear doors and a pad underneath to protect the surface.
It's a little unclear to me whether the 150lb weight limit assumes some kind of roof rack that brings the load to (reinforced?) sides
Thanks
Old Aug 23, 2022 | 09:40 AM
Badhobz's Avatar
Badhobz
im 99% sure its fine to exceed that weight restriction. Im not even sure why they have that weight restriction as the car is designed to withstand supporting its entire weight on its roof in case of a rollover.
https://bestride.com/news/woman-walk...s-rx-350-video
Old Aug 23, 2022 | 11:59 AM
pentaprism's Avatar
pentaprism
It's dynamic vs static load. If the vehicle hits a bump on the road, something with a static weight of 150 lbs can exert a dynamic force much greater than 150 lbs.
This is similar to (or opposite of?) the rating on waterproof watches. A watch is rated (static) waterproofed to 50m does not necessarily mean the watch will be OK if it is worn by a diver down to 50m.
Old Aug 23, 2022 | 12:58 PM
Badhobz's Avatar
Badhobz
understandable and apt analogy, but a static weight of 150lbs isn't going to be 4x weight of the RX which its designed to support in case of rollover protection.
It might just be the roof rails themselves are rated at 150lbs. not the roof structure.
Old Aug 23, 2022 | 02:42 PM
jrobe's Avatar
jrobe
We put 2 fairly heavy kayaks on our Rx350 roof regularly with no problems. You luggage is going to be lighter than that. That being said, I wouldn't put anything directly on the roof and risk scratching the paint even with padding. Every time you hit a bump or hit the brakes, it will likely slide a little on the painted surface. If you are going to carry anything on the roof, get some crossbars and the proper roof carrying equipment (storage boxes, etc.). They are not that expensive if you can afford a $50k car.
Old Aug 24, 2022 | 10:19 AM
toyotaman7's Avatar
toyotaman7
I don't think the roof panel itself is rated for ANY load what so ever. The load rating is for anything that is supported by the roof rails.
No car can support any load on the roof panel. That is a thin sheet metal they easily bends.
Old Sep 4, 2022 | 11:47 AM
Tarkus's Avatar
Tarkus
If I may be so bold, where did you get your engineering degree?
joe311
RX - 4th Gen (2016-2022)
139
Mar 3, 2026 09:48 AM
autotech13
45
Apr 18, 2022 02:06 PM
MattyB1234
LX - 3rd Gen (2008-2021)
Nov 20, 2021 04:31 PM
Surfy
Mar 10, 2021 06:34 AM
