Low towing capacity vs highlander
I'm pretty sure the highlander's capacity was 5000 lbs to the Lexus 3500. That's why the after market hitch options have a range in capacity 3500 to 6000 lb (Curt, Cequent, vs Draw-tite). This was true for the previous gen HL anyway (in V6 4WD).
If the Lexus has the tow package I'm pretty sure they have the same brake rotors / callipers, engine, transmission and oil cooler. I was told the difference is the softer springs in the Lexus and heavier weight of the Lexus caused the lower towing capacity.
That said, these seem like "guidelines" and 5000 lbs is a lot in a highlander, and looks like 3500 lbs is low for the RX if well balanced.
From web site:
With a 3.5-liter V6 engine, the 2020 Toyota Highlander can move a lot of cargo. If you are traveling for a weekend getaway or a cross-country road trip, you can rely on the new Highlander to help you take what you need. This SUV can tow a total of 5,000 pounds for all your travel needs. Jan 6, 2020
5000lb capacity comes with the V6 highlander. I would bet a FWD V6 Highlander is hard to find.
I tow a 2700 lb boat right now with no issues. I'm looking at some 3000-3100 now but that would be close to 4k with trailer
I'm sure with trailer brakes it would be fine it's just the liability thing if something happens.Huh
The RX350 towing package includes engine oil and transmission oil coolers! Do not burn your tranny! It's very expensive to repair and replace and needless to say the same with your engine.
