AGM Battery?
Lexus batteries do fail early once in a while. The battery on my 2016 RX 350 failed after 1 year and 4 months. One morning my car wouldn’t start - it was July so temperature wasn’t an issue. I jump started the car and went to my dealer. As soon as I got there and turned off the engine, the car wouldn’t start again. The dealer tested the battery and found one dead cell in it which makes the whole battery unusable. They replaced it under warranty no questions asked.
Sooo... how long does the warranty last? haha. I'm pretty sure I"m out of it as it's been 2.5 years.
On cold starts it takes a second to start up
Does anyone know what the exact size I need to buy?
The size if the battery is : Group 24F
Found this thread with the exact same issue.. Looks like I need a new battery after only 2.5 years
https://www.clublexus.com/forums/rx-...showing-2.html
Thanks! The warranty for the battery may be different than the other stuff.
I'll prob take a trip to the dealer soon
I bought a similar brick-sized battery booster a couple of years ago from Walmart for just $40. Costco is selling a nicer-looking one for less than $60, I recall.
Only used my booster once, in the Costco parking lot, on a pickup truck in the parking spot next to me. A V8 and when he tried to start on his battery the solenoid would just click. We hooked up my little booster, and the first attempt was just maybe one revolution. Stopped, waited for 10 seconds, then tried again. Slower-than-normal cranking speed, but the engine fired right up! Amazing for such a little box. Lithium cells can flow a LOT of current. They'll discharge fast, of course.
Edit - Every website I go to .. says this 24F battery is not compatible..
Just got it fixed!
The service advisor told me that the new Lexus vehicles like mine have way more sensors than before. He was telling me that this can cause a good amount of battery drain on the car if you don't drive it for a while. He also told me that mercedes vehicles have two batteries one for the engine and one for the sensor. It's like he was trying to sell me on a mercedes lol.
My vehicle is 2.5 years old but has 24,000 miles on it. They replaced the battery under warranty free of charge.
Just got it fixed!
Just got it fixed!
Today's batteries have to do a lot more than they used to, in the past one could get away with cheap batteries, not anymore! Now if you go cheap you'll spend more in so far as you'll have to replace the battery more often. Get the best you can afford.
Do you get this notice?
