Park and listen
Old Mar 8, 2018 | 10:18 AM
pdetorres's Avatar
pdetorres
Default Park and listen
I sometimes park , want to turn the engine off but keep listening to the radio. I can't figure out how to do this without turning the car off ,losing the radio and restarting in ignition/accessory mode. I have gone over the manual with no answer.
How do I turn the engine off but do not interrupt the media?
Pablo
Old Mar 8, 2018 | 10:53 AM
Jiggz858's Avatar
Jiggz858
As far as I know this cannot be done without turning it off first and then as you said, turning on the accessory mode. The other question that was also asked before by others and also by me is how to extend the accessory mode to more than 20 mins before it auto shuts off.
Old Mar 8, 2018 | 11:24 AM
Mike728's Avatar
Mike728
It can be done by following the method that was already noted:
Originally Posted by PatrixUSA
...instead of placing transmission into Park - place the transmission into Neutral > then push Engine Start / Stop to turn engine off > then place transmission into Park = this should place car into accessory mode with engine off, leaving radio / media powered and playing until power save mode is activated to save battery power (after about 20 mins).
I don't think the 20min limit can be bypassed, though.
Old Mar 8, 2018 | 12:20 PM
Marqevans's Avatar
Marqevans
Just to follow up, the manual confirms the posted operation works on the RX = Page 221 in online manual:
"When stopping the engine with the shift lever in a position other than P - If the engine is stopped with the shift lever in a position other than P, the engine switch will not be turned off but instead be turned to ACCESSORY mode."
In other words, shut the car off before you shift into Park, the radio will stay on.
Old Mar 8, 2018 | 01:25 PM
Jiggz858's Avatar
Jiggz858
Thanks. Learn something new everyday with this vehicle.
Old Mar 8, 2018 | 03:42 PM
GSFRX350's Avatar
GSFRX350
Try this when you want to continue listening to audio in accessory mode (ACC mode)...
This works on the IS, should also work on the RX. Just don't forget to turn the power off prior to leaving the car (push engine start / stop button again to power everything down). Good luck, and welcome to Club Lexus.
If you don't turn off the car it won't let you lock it - gets emotional and makes noises.
changhiskh
RX - 3rd Gen (2010-2015)
Mar 24, 2019 08:01 AM
fiddler1
Oct 1, 2017 09:29 AM
srv777
Nov 9, 2016 05:14 PM
typocl
NX - 1st Gen (2015-2021)
Mar 18, 2015 03:15 PM
salvadorik
Jan 5, 2014 10:42 PM
