Replacing wiper blades?
#91
2018 Wiper insert replacement
How do you replace?
Prior Lexus models you could replace the rubber, and re-use the herringbone metal.
The new OEM wipers have a plastic tab on the end. I can’t find a video or how to do.
Anyone have experience?
Thx
Thx
#92
I think these are beam wipers and you must replace the whole blade. Also to raise the arms, once car is shut off (within 40 sec I think) push the wiper stalk up and hold it for a few seconds, this will make the wipers move up on the windshield and stop dead centre.
ravenuer (10-11-20)
#93
Did they change the wiper blade design from the 2016 model?
In the 2016 Rx manual, page 601, there is a section on how to replace the wiper blade inserts.
http://s3.amazonaws.com/lexus.site.t...U/OM0E012U.pdf
#94
It's the same on my 2018. It is a beam blade, and there is an insert that can be replaced as per the manual if you want to save a few bucks per blade. Fiddling and twiddling with the inserts doesn't look worth the little bit of savings, to me.
Cocal (10-11-20)
#95
I agree. I use Trico replacement blades which are a perfect fit.
#99
You can also use silicone spray to make them last. I've been doing this for yeas now.
#100
Rubbing alcohol works well. I have the originals on my ES which is nearly two years old now. Still clear perfectly.
#101
Doesn’t applying 303 or silicone spray to the wipers, make a smeary mess on the windshield? I’ve found the wax foams used in car washes make my windows atrocious to clean. I end up cleaning my windshield & wiper blades with alcohol to get the smeary mess off.
#102
Silicone will not make them smear gadgetman1. What I do is once a year I'll take a paper towel, fold it, then spray some glass cleaner on it and wipe the blades off until no more black stuff comes off, then I take a clean paper towel and spray some silicone and wipe the blade a couple of times, that it. Been doing that for years.
Oh, one more thing, my wife's 2013 ES has the original wiper blades on it.
#103
#104
As for windshield wipers replacement, check with your local dealer parts department - inserts are about $10/each, and they will replace them for your on the spot at no extra charge.
Replacement blades are also available, but they are double the price.
NX200 (10-19-20)
#105
Wiper blade options
I tried to do a search for wipe blade refill. Is this even possible? I order one from Amazon and they do not fit, the connection is different. 2017 rx350 F. Refill possible or must buy new? Any suggestions?
Thanks
Thanks
