Tyre Pressure
Old Apr 5, 2018 | 06:49 PM
  #31
Htony's Avatar
Htony
Originally Posted by LordBowral
What's the consensus on the best tyre pressure please? ...comfort biased.. but don't want to wear the tyres out unnecessarily .Also what mileage should I get out of them . We seem to get all Dunlop's here in Australia not the Michelins the US cars come with ....
That is funny, you have to ask. Only I increase pressure couple PSI when my car is loaded or going on long distance high speed cruising. Also rotate tires, your suspension and alignment is in order.
Old Apr 5, 2018 | 06:52 PM
  #32
Htony's Avatar
Htony
Originally Posted by My450H
that's found in the door?
I'm thinking for new tires I should use 38 psi for comfort and better mileage. Good idea?
Your ride will be hard and bouncy.
Old Aug 23, 2019 | 05:59 PM
  #33
whiteghost's Avatar
whiteghost
Default What tire pressure do you run on your stock 20” wheels?
In our last 2013 Lexus Rx350, I ran exactly what it recommended on the door jamb sticker. However it just about ruined a set of tires as it was to low and wore the outer edges prematurely. Lexus service rep said to run it several lbs higher, and switched to that and everything was fine from there on.
Looks like the dealer put in 38psi as we just bought the vehicle. The sticker says 33psi.
What at psi are you running on your stock 20’s?
Old Aug 27, 2019 | 01:06 PM
  #34
makaRX350's Avatar
makaRX350
From my previous experience on all my vehicles, I always run ~4-6 psi less than the Max PSI rating on the "Tire" itself (regardless what brand of tire, etc). I also noticed the RX350 had more outer wear on the tires before i bought the car. After purchasing the car, I added the pressure i normally run my tires ~4-6 psi less than Max of Actual tire rating. Car runs smooth and tires will last longer. I also have a 4 runner and have had the same tires for nearly 3 years with normal driving, approximately 40,000 miles on the tires and when i went to get a maintenance check 2 weeks ago, they mentioned that my tires still looked semi brand new.
Old Apr 18, 2021 | 09:03 AM
  #35
thehaviet's Avatar
thehaviet
Default '21 RX350 F-Sport New Owner Settings
Hi all, we just received our car this weekend.
What are some of the settings we should go through as new owner? What Tire pressure is everyone running? 33psi?
Old Apr 18, 2021 | 09:35 AM
  #36
jollick's Avatar
jollick
Congratulations! I keep pressure at 33psi.
Old Apr 18, 2021 | 09:46 AM
  #37
Cocal's Avatar
Cocal
Tire pressure is listed on the door below the lock, on mine it says 34 psi, but this can be changed according to need-use-conditions
Old Apr 18, 2021 | 09:52 AM
  #38
autotech13's Avatar
autotech13
33 psi. Label located on driver's door jam.
Old Apr 18, 2021 | 09:59 AM
  #39
Cocal's Avatar
Cocal
What size wheels do you have?
I find it unusual that there'd be a difference between the years, mine are 20" and it had Michelin tires, but I don't think that tire brand maked a difference.
Maybe it's adjusted for pot-holes
Old Apr 18, 2021 | 10:37 AM
  #40
thehaviet's Avatar
thehaviet
235/55/20 are the tires.
I believe 33 PSI are for max load, when you typically have 5 passengers and a few luggage? Curious if anyone typically runs their tires under 33 psi.
Any other settings we should take a look at?
Old Apr 18, 2021 | 10:58 AM
  #41
TechNut's Avatar
TechNut
Veteran: Navy
Congrats on your new ride!
If you go look at the bottom sticky thread for this subforum, it is an FAQ thread and it has a section for Lexus Personalized Settings. Lexus used to produce a nice PDF that compiled all the customizable settings but now you have to dig through the back of the owner's manual. Here is the most recent link I can locate for the compiled settings: 18RX 350_CST (lexus.com). The title suggests this is for a 2018 model year but if you open the document it is actually for the 2019 model year. This listing in the FAQ thread is a little jumbled and you will find some of the links take you back to the 2015 model year which is the previous generation.
Now, as to your question, which settings have we implemented: Item 5 identifies the doors to unlock when gripping the handle and I changed it to unlock all doors because my wife is with me more often than not. If my wife was the normal driver getting in a dark parking lot, I would have left this to only unlock the driver's door. As to number 18, I set the "Driver's Easy Access" to "partial" rather than the default of "full" which resulted in too much movement for my taste. I also like to change setting #38 to 5 for the lane change blinks since the default of 3 is just too few for me (this will vary a great deal by how aggressively you have to drive for your highways). There are also settings that aren't listed on this document but they are referenced in the back of the 2021 owners manual. For example, I have them turn off the seat belt buzzers, but I understand from previous posts that not all dealers will make this change. Probably depends on state laws and liability concerns.
I hope that helps. Of course, these are called "personalized settings" for a reason. What works for one person is not necessarily optimal for the next. You may want to just experiment with some of these, except those the dealer has to make which are typically performed at the first service.
Old Apr 18, 2021 | 01:28 PM
  #42
websurfer's Avatar
websurfer
Congrats on your new ride. Looks awesome.
Old Apr 19, 2021 | 08:51 PM
  #43
JeffKeryk's Avatar
JeffKeryk
Beautiful car. Silver on red. Silver with the F Sport wheels is gorgeous!
Old Apr 20, 2021 | 04:51 AM
  #44
thehaviet's Avatar
thehaviet
Thanks. We really liking it so far.
Old Apr 20, 2021 | 04:53 AM
  #45
thehaviet's Avatar
thehaviet
Thanks. It's actually gray, but we do like the color combo. It does pop quite a bit.
