24 hrs clock
Old Apr 5, 2017 | 02:26 PM
Cocal's Avatar
Cocal
Default 24 hrs clock
Does anyone know how to change the clock from AM & PM to 24 hrs in a 2017 RX 350?
I've looked high & low and could only find a choice between standard & daylight saving time and nothing else.
Tanks in advance
Old Apr 5, 2017 | 03:24 PM
skiracer's Avatar
skiracer
I was wondering the same thing since its annoying to see in the Odometer section...
Old Apr 6, 2017 | 06:45 AM
17RX350F's Avatar
17RX350F
Me as well... my clock (both dash and driver area) currently shows an hour behind and I don't know why. I can't find anywhere to change it in the manual with a navigation system?
I assume my issue is daylight savings when they changed it to be a longer and that is why but not sure, does anyone else have this problem?
If anyone knows how to update the clock please let me know... thanks!
Old Apr 6, 2017 | 06:56 AM
Gibster's Avatar
Gibster
I'm not sure if the 2017 clock adjustments are the same as the 2016, but here are the instructions from the '16 manual...
Old Apr 6, 2017 | 07:23 AM
17RX350F's Avatar
17RX350F
Thanks, my 17 manual had the same thing listed... just the option to change from 12 to 24 hours with navigation.
Another user mentioned time zones, is that setting in another location? With navigation I thought our car's pulls the time from a time server like PC's do but I don't see any option to override or change it.
Old Apr 6, 2017 | 07:26 AM
sderman's Avatar
sderman
I found it in the navigation manual. A suggestion: Download the manuals from the Lexus site and save the pdfs. In this case go to the navigation manual and search (using Control plus F) for the word Daylight. Easily found.
Old Apr 6, 2017 | 07:33 AM
17RX350F's Avatar
17RX350F
I actually tried that as one and two words before, see attached, did not find anything in my manual. I can only find items with clock or time. Can you tell me the page you found it on?
Old Apr 6, 2017 | 07:40 AM
17RX350F's Avatar
17RX350F
Here is all I can find...
Looks like it cannot be changed with a navigation system as it pulls from GPS?
I am going to hit the SOS button and see if they can do anything since it pulls from GPS maybe it doesn't know I am EST time in their records?
Does anyone else have this problem with the time being off by 1 hour?
Old Apr 6, 2017 | 07:53 AM
17RX350F's Avatar
17RX350F
Sorry guys... it was in the Navigation Manual and not the main one... here are the setting if anyone else needs them.
Old Apr 6, 2017 | 07:55 AM
FastFord's Avatar
FastFord
Sounds like a daylight savings issue.
Get into setup, then general, then clock, then daylight savings, and turn it off or on depending what you want.
Then watch the clock spin!
Old Apr 6, 2017 | 11:05 AM
offroad200's Avatar
offroad200
Tanks in advance
You change it in the settings in the instrument cluster. Under the gear icon you'll see clock and the option for 12H or 24H.
Old Apr 6, 2017 | 11:24 AM
Cocal's Avatar
Cocal
Thanks 17RX350F, but I can find this page in my manuals, which manual was it in? and which page? Greatly Appreciated!
Cocal
Old Apr 6, 2017 | 11:33 AM
17RX350F's Avatar
17RX350F
Cocal
No problem... here is everything I could find about the clock in all manuals downloaded from Lexus.
Detailed clock settings - Navigation Manual - Page 61
Normal clock settings - Main Manual - Pages 100 & 526
Old Apr 6, 2017 | 12:19 PM
ggebhardt's Avatar
ggebhardt
You can download the PDF manual to your phone and use the search function and find about what ever you need.
Saved my butt a few times!
Old Apr 6, 2017 | 03:16 PM
skiracer's Avatar
skiracer
So we navigate to this screen using the buttons on the steering wheel?
