Steering off to the left - Is it Alignment
Old Oct 17, 2016 | 05:15 AM
sankomtech's Avatar
sankomtech
Default Steering off to the left - Is it Alignment
Am I **** or someone else also see this. On My new 2016 RX350 F-Sport bought 2 weeks - the steering wheel is at 11:55 clock when the car is straight on a new paved road level. I saw this on many different roads - highway, side roads...
How can this be fixed, is this an alignment issue...Can we expect this on a new car...
Any help will be appreciated...
Old Oct 17, 2016 | 05:30 AM
aznkorboi's Avatar
aznkorboi
Yes. Take it to the dealer. THe funny thing is my wife's IS does this. I still haven't gotten it fixed yet. HOwever my RX does NOT do this. So yes, take it to the dealer and have them align it.
Old Oct 17, 2016 | 09:16 AM
FastFord's Avatar
FastFord
Yes, get this corrected ASAP...do not wait for a 5 or 10K inspection. Your tires will probably start to wear incorrectly. This was the same thing I had on my F Sport and the tires wore badly. I bet your alignment is out along with the wheel at 1155. This is a free check and correction...it's part of your warranty.
Old Oct 17, 2016 | 09:20 AM
kitlz's Avatar
kitlz
No, I don't play soccer!
Alignment is covered for the first year/12K miles, Check the tire pressure too. Dealers are notorious for overfilling. BTW, the road in your picture has some noticeable crowning. Probably not the ideal way to test the alignment, Good luck.
Old Oct 17, 2016 | 03:39 PM
sc400's Avatar
sc400
My RX350's steering was off center about 5 degrees. The alignment was fine. It looks like factory didn't center the wheel so I took it back to the dealer. I declined the wheel alignment and instead asked them to adjust the steering rod. They did and now my steering wheel is centered.
Old Oct 17, 2016 | 04:44 PM
sankomtech's Avatar
sankomtech
I have an appt set for tomorrow. Thanks all for the feedback. I will tell them to do the alignment, and if the alignment wont fix the centering, they should center the steering wheel.
Question is can they center the steering wheel while the car is on the alignment pad. I want this perfect, as no way can a $60K car be off center ...
Old Oct 17, 2016 | 04:46 PM
sankomtech's Avatar
sankomtech
I did not test it on this road. I went to a new paved road, and then a major highway (center lane) both when I center the wheel, it was going right. There is no pull on either direction.
Old Oct 18, 2016 | 04:11 AM
ggebhardt's Avatar
ggebhardt
The steering wheel not being level is not a sure sign that the alignment is bad. It can just be a sign they did not set the wheel level before they aligned the front end.
Old Oct 18, 2016 | 05:33 AM
sankomtech's Avatar
sankomtech
All so here is my alignment check report when I dropped off the car. Scary stuff that a new car (which I trust) has an alignment issue and I have not even driven 570 miles.
All should ask the dealer to check it as don't trust - my first experience in over 3 decades of owning new cars...
Will post the final results when I pickup the car tonight..
Old Oct 18, 2016 | 07:17 AM
Bearcat's Avatar
Bearcat
My turns about exactly the same to the left when going straight...looks like I need to go in too. Thanks!
Old Oct 19, 2016 | 12:22 PM
sankomtech's Avatar
sankomtech
You guys wont believe it. Well yesterday I went to pick up my car after the alignment. Now they have lost my key ... They cant find the keys - come on the car is barely 500 miles and two weeks old.
So they gave me a loaner and said they are ordering a new key ...
Old Oct 19, 2016 | 12:39 PM
Bearcat's Avatar
Bearcat
Did you get a new printout?
Old Oct 19, 2016 | 01:33 PM
sankomtech's Avatar
sankomtech
Yes got it, will scan and post it. But I still have to check the car, if I get it back ... ughhhh
Old Oct 19, 2016 | 04:50 PM
cremaster's Avatar
cremaster
my wife's car drove off the lot w/ 12 miles on it w/ the steering off center. she test drove it so she didn't notice until i drove the car home and immediately noticed it. the dealer did a full alignment under warranty and fixed the steering wheel. were they in a rush to push these cars out? everything else about the car is fine from what we can tell.
Old Oct 21, 2016 | 01:24 PM
sankomtech's Avatar
sankomtech
Update:
So after the alignment the steering was still off center. Today morning I went to the Service Center, call the technician, he drove with me, and confirmed that yes there is a problem and will be fixed next week Wednesday ...
Lets hope this is my last trip for that issue ...
