Test PCS Pre-Collision System, not working
Old Jun 15, 2016 | 04:34 PM
EvanJ's Avatar
EvanJ
Default Test PCS Pre-Collision System, not working
I feel that my PCS (Pre-collision system) is not working. Since my family also own a 2015 Acura MDX, I can easily test and approve that Accra's collision warning system works without much risk. But with my RX 350, I just could not make it beep at all, even after set the sensor to the most sensitive level. Wonder if anyone tested it. Does it use front camera? I think my front camera broke too. It sometimes flash like crazy. i recorded a video of it. I will definitely go back to dealer again, but not 100% sure about the PCS.
https://goo.gl/photos/udAiBtmVMJP939Ge6
Old Jun 15, 2016 | 04:41 PM
toyotaman7's Avatar
toyotaman7
I have tested it couple of times. It beeps and then locks up the wheels.
Old Jun 15, 2016 | 04:43 PM
EvanJ's Avatar
EvanJ
thanks. I will ask dealer to check PCS and will also test on the loaner if it is equipped with it.
Old Jun 15, 2016 | 05:19 PM
Mdme's Avatar
Mdme
It's really set to only intervene at the last moment. Especially when compared to my Infiniti, I question if it's even there but I have certainly gotten it to beep.
Old Jun 15, 2016 | 06:42 PM
dchar's Avatar
dchar
It uses the cameras mounted above the rearview mirror, not the one mounted on the grille used for parking.
You definitely have a problem with the front parking camera though.
Old Jun 16, 2016 | 01:53 AM
ggebhardt's Avatar
ggebhardt
I thought the system uses the radar system through the front emblem for the emergency braking.
Old Jun 16, 2016 | 02:55 AM
kitlz's Avatar
kitlz
No, I don't play soccer!
EvanJ, to test PCS, find an empty parking lot or road. Get up to 25 MPH, then press the brake harder than normal. It should kick in. I haven't tried it on the 4RXh yet but did have the brake warning flash on the dash when going around someone making a turn. Definitely have the dealer check the front cameras. Good luck and keep us posted..
Old Jun 16, 2016 | 07:54 AM
sirtiger's Avatar
sirtiger
your car must be a lemon. The other thread the OP posted about the car breaking down at 30km
Old Jun 16, 2016 | 08:15 AM
coolsaber's Avatar
coolsaber
PCS uses the radar behind the front emblem and the stereo camera below the rear view mirror. If any issues with line of sight due to physical blockage, refraction, or general system failure, the system would fault out. The issue with front camera for pano view is not going to directly affect the PCS system. However, seeing the OP had a breakdown with ECU replacement, it wouldn't surprise me if these issues are related in some way.
Old Jun 16, 2016 | 03:54 PM
EvanJ's Avatar
EvanJ
thank you all. I have sent the car back to dealership this morning. Will test again per your suggestion when it comes back to me.
Yurjan
ES - 7th Gen (2019-2025)
22
Jan 15, 2019 04:38 AM
J3ffrey
Sep 5, 2016 01:23 PM
avanchieri
Aug 23, 2016 01:22 PM
whitetooth
May 13, 2014 08:33 AM
Larmik
RX - 3rd Gen (2010-2015)
Sep 24, 2012 11:51 AM
