Temporary Override of Partial Trunk Open?
Old Feb 27, 2016 | 12:14 PM
daryll40's Avatar
daryll40
Default Temporary Override of Partial Trunk Open?
A nice feature on the 4RX is the ability to open the trunk hatch only part of the way. In my case, I park the vehicle in my garage under a low beam and 4 out of 5 is a great position to prevent dings etc. That being said, I've whacked my head twice while loading the vehicle while out (of my garage). I think I can get used to it...the whacks were minor. But is there an easy way to "override" the "less than 5/full open" setting"? With the push of a button? Or even if I just use my arm to force open against the pistons? Will that harm the pistons? It would be nice if there was a secret "double click" thing that's not easy to accidentially trigger but easy to use to get the hatch to full open on occasion.
Old Feb 28, 2016 | 08:51 AM
roblim's Avatar
roblim
I feel your pain (literally). There are really low ceilings at my work's parking structure. Thanks to the fire sprinker piping, I have to set the max open setting to something that i need to crouch to access the trunk and sometimes i hit my head on the low setting. One thing you should be aware of is that the open height is customizable. You're not limited to the pre-programmed settings, you can set it to whatever height you want. That said, I think the next innovation the RX should have is a sensor on the tailgate to detect objects and stop automatically to prevent damaging the tailgate. I don't think you can hurt anything by manually moving the lid to open further. It doesnt take much effort to re-adjust the tailgate so i think it was designed with that use in mind.
Old Feb 28, 2016 | 09:21 AM
daryll40's Avatar
daryll40
This is news to me. Can you elaborate? How do I set the trunk to open to, say, 4 1/2?
Old Feb 28, 2016 | 09:24 AM
dchar's Avatar
dchar
Just push it to the height you want, and press and hold the trunk close button on the tailgate for several seconds.
Old Feb 28, 2016 | 09:29 AM
daryll40's Avatar
daryll40
Son of a gun! Great tip! Thank you!
Old Feb 28, 2016 | 01:57 PM
roblim's Avatar
roblim
I learned that tip on these forums. It's not clear from the settings alone but it's most certainly in the manual which I did not read.
Old Feb 28, 2016 | 06:08 PM
dfc350's Avatar
dfc350
I think I also remember running across a setting for this in the nav system.
Just found it - p. 702 in the Owner's Manual has "Power back door opening position" plus about a dozen other settings for the back door.
EDIT: Just noticed that the opening position setting is the only one you can change. The rest have to be done by a dealer.
vantage78
LS - 5th Gen (2018-present)
Jan 14, 2019 07:52 AM
jimisbell
Jul 8, 2017 10:28 PM
Muti007
Sep 25, 2015 01:49 PM
B@tm@n
Jan 30, 2007 04:36 PM
dat-is350
Dec 28, 2006 02:36 PM
