Wheel torque specs?
Old Jan 15, 2016 | 10:05 PM
skiracer's Avatar
skiracer
Default Wheel torque specs?
Trying to put on the wheel locks and can't seem to find wheel torque specs. In owners manual, page 653 it says "have the wheel nuts tightened with a torque wrench of 76 ft lbs. However, they're referring to the spare donut.
So, not sure if spare donut has same torque specs as the regular wheel.
Also, anyone know what size socket i need for the lug nuts. I know my 13/16" socket will work, but i'm sure the lugnuts are Metric and the wheel lock doesn't work with a 13/16" socket..... I don't have any metric sockets big enough so i need to go buy one
Old Jan 16, 2016 | 06:36 AM
rayaans's Avatar
rayaans
76 foot pounds is correct. been the same on all RX's if I remember correctly
Old Jan 16, 2016 | 11:18 AM
dfc350's Avatar
dfc350
I just installed <a href="http://www.ebay.com/itm/LEXUS-OEM-FACTORY-WHEEL-LOCK-SET-2016-RX350-RX450H-/331753594401" target="_blank">these wheel locks</a> on my 4RX 350 this morning using the lug wrench that came with the car. The wrench is 13/16".
Old Jan 16, 2016 | 01:05 PM
skiracer's Avatar
skiracer
stopped by the dealer to get my license plate brackets installed and asked them socket size for Lugnuts. They said 21MM and i picked a 21MM deep socket so i can use for my torque wrench
Old Jan 16, 2016 | 05:23 PM
KANG's Avatar
KANG
Registered User
wheels locks are not meant to be torqued the same as wheel nuts. just make them littler tighter then snug. I work at a car dealership, the mechanics don't torque wheel locks like the regular nuts.
Old Jan 16, 2016 | 07:36 PM
sderman's Avatar
sderman
Nope, you are wrong. McGard, the manufacturer of the wheel locks on my last 17 years of Lexus', says:
"Using the McGard key and a wrench, tighten each lock to the torque specified in your vehicle owner’s manual. For best results, use a torque wrench and socket."
Their link is below
http://www.mcgard.com/index.php/cust...llationremoval
You might wish to inform your dealership's mechanics and service managers.
Old Jan 18, 2016 | 05:44 PM
toyotaman7's Avatar
toyotaman7
The car is designed to have 5 lug nuts torqued at 76 lb.ft in order to withstand the side loads in turns and other situations.
If you do not torque one then you are cutting that safety factor and risk snapping lug nuts.
You MUST torque all 5 lug nuts.
Old Dec 29, 2023 | 12:18 PM
JDGS350AWD's Avatar
JDGS350AWD
4th Gear
Their link is below
and for the love of God torque the wheel to the factory spec I'm tired of 140 ft lbs on lugs especially on my Lexus spec'd at 76 ft lbs.
Old Mar 11, 2024 | 04:34 PM
FastFord's Avatar
FastFord
Coming up to that time of the year for some of us....thought I would bring it to the front page.
Old Mar 11, 2024 | 08:53 PM
15RX98422's Avatar
15RX98422
I usually have Discount Tires rotate my tires every 5k miles. Last time, I took my car in for rotation at 10k miles and asked them to install the wheel lock nuts. They did it for free for obvious reasons.
Old Aug 6, 2024 | 10:10 AM
fondoo's Avatar
fondoo
Default torque spec for wheel nut???
does anyone know what the torque spec for the wheel nut on the 2022 RX350L??
Old Aug 6, 2024 | 10:25 AM
Quantum501's Avatar
Quantum501
Should be 76 ft lbs, but to be sure you can check section 8.1 in your owners manual.
Coconut
Mar 31, 2009 04:36 PM
ISF_GG
Wheels, Tires & Brakes Forum
Mar 17, 2008 11:51 AM
Flipsonic
Dec 29, 2006 02:21 PM
peterGX470
GX - 1st Gen (2003-2009)
Nov 27, 2005 08:32 AM
ChuH
Jan 17, 2003 04:44 AM
