Hesitation problem at various speeds (TSB info post #159)
Old Feb 4, 2019 | 06:04 AM
  #1006
D4V1D's Avatar
D4V1D
Everyone's personal tastes are different, I suppose. We just traded our '15 NX for a new '19 RX and we both absolutely love it. No issues with engine/transmission at all. Drives like you said, "a dream".
Old Feb 4, 2019 | 06:09 AM
  #1007
JSracer's Avatar
JSracer
there is a reason some go with the rx450
Old Feb 4, 2019 | 06:23 AM
  #1008
mikemu30's Avatar
mikemu30
Try Sport mode. Ours is a 17 and the shift points are just fine. Hybrid? Nah.
Old Feb 4, 2019 | 07:44 AM
  #1009
ravenuer's Avatar
ravenuer
Why not try resetting the transmission ECU?
Old Feb 4, 2019 | 08:16 AM
  #1010
Nail34's Avatar
Nail34
I have a '17 350 f-sport with 15k miles. I really like car, more today than when I bought it. The TSB helped enormously in that regard. I am very happy with my purchase.
The following is a quote from an edmunds review and I found it to be the best description of the transmission and it's problems. Many owners do not have or don't notice these problems. The link to the full review is below.
"The 8-speed transmission regularly upshifts when it can't maintain speed and shifts back down within four seconds, then repeats. It is the constant attempt to keep engine revs under 1,800 rpm for fuel economy that causes the groaning and very slight vibration. The engine is laboring, even under the light throttle of a gentle driver, the revs are so low. Downshifting manually a gear or two completely eliminates it, making the engine very smooth and quiet. The transmission is reluctant to downshift when speed drops on a hill with throttle still applied. When climbing a steep hill into our neighborhood, I must make a sharp turn. I feather the throttle to time my speed reduction to reach 6 or 7 mph as I reach the sharp corner, still climbing steeply. As I turn it gets steeper and I add throttle. The speed drops further because it's still in third gear. The torque converter sounds like it is being abused. The car slows to about two mph, slower than I want to go before dropping to second, but if I add enough throttle to make it downshift when it should it would surge ahead too strongly for the turn. It never selects first, which is what is needed. I now shift manually every time I climb any hill to prevent these problems. When I do, the engine is quiet, smooth, sounds happy at 2,000-2,500 rpm and of course there is no hunting."
https://www.edmunds.com/lexus/rx-350...0849329070080/
Old Feb 4, 2019 | 08:39 AM
  #1011
Usual's Avatar
Usual
I have an '18 and have no issues with the shift points. Even when I floor it to pass the shifts are quick and smooth.
When the car was new, I did find eco mode very unresponsive, but I tried it again recently (after about 5K km) and it downshifts quite readily now. I assume it has adjusted to my heavy foot and/or loosened up mechanically.
Old Feb 4, 2019 | 09:53 AM
  #1012
technodis's Avatar
technodis
This is something we can do at home? I had the dealer do it a few times when I complained about it, but did not realize this is something that I can do myself.
Old Feb 4, 2019 | 02:57 PM
  #1013
Freds430's Avatar
Freds430
This is one of many reasons we bought a RX450h. The transmission could not be smoother. Used the hybrid was $1,500 more than the RX 350's on the Lexus lot. A true no brainer. Had ten Acura's before coming over to Lexus six years ago. Acura's used to be as dependable as Lexus but no more. J D Power ranks them well below average. They rank the RX the most dependable in the mid size premium SUV category. For the same reason would never touch a German SUV.
Old Feb 4, 2019 | 03:46 PM
  #1014
ravenuer's Avatar
ravenuer
I believe you can accomplish that by disconnecting the battery for about 30 min or so.
Old Feb 9, 2019 | 07:39 AM
  #1015
keneaise's Avatar
keneaise
Default Hesitaion problem
Originally Posted by Larryu
I am a new member and first time Lexus owner of the 2016 RX 350. I am finding a real hesitation issue with my car. I took it into the dealer and after several days told me it is working as it should?
Am I the only one with this problem? Please let me know if anyone else has it. I am in conversation with Lexus HQ about this issue.
There are many posts about this on here. My 2019 RX hesitates badly with acceleration. Many think it is the ECU that needs to be reset to re-learn your driving habits. During the initial break-in of 1,000 miles, most of us are taking it easy. The recommendation is that you do not any fast starts until after that period. I drive much more aggressively now than I did during break-in. Some people were able to get a reset. I asked my dealer and he said they never heard of it. I still have the problem and am keeping it in sport mode and using premium Shell gas to minimize the annoyance.
-lj
Old Feb 9, 2019 | 12:49 PM
  #1016
GSFRX350's Avatar
GSFRX350
-lj
I have to say that's crap - that person you spoke to obviously doesn't know. Did you ask them to check with someone else, did you push the matter? There is so much written about this over many websites not just this forum, many different Lexus models too.
Contact them again OR go to another dealer, the RX350 transmission can be reset, my dealer did it without me asking, I only mentioned the hesitation, they found nothing wrong and said they reset the transmission memory.
Old Feb 9, 2019 | 06:05 PM
  #1017
jowens100's Avatar
jowens100
Default Slight transmission hesitation at 55-65 mph
I have a 2017 RX350 for one week now. Driving on interstate highway the transmission doesn't sound right at 55-65 but sounds smooth and quiet once i'm above 65mph.
It is an 8 speed so maybe what i'm hearing is the shifting to another gear between 55-65mph.
Otherwise the car is great.
Thoughts? Thanks.
Old Feb 9, 2019 | 06:16 PM
  #1018
mikemu30's Avatar
mikemu30
Thoughts? Thanks.
What do you hear? Its probably not quite in 8 at 55 but that doesnt mean there should be a noise. Our 17 is buttery smooth every step of the way in particular on the highway.
Old Feb 10, 2019 | 02:29 AM
  #1019
jowens100's Avatar
jowens100
I am in ECO mode. Could it be the transmission is slower to respond in ECO therefore causing the hesitation?
Old Feb 10, 2019 | 06:17 AM
  #1020
mikemu30's Avatar
mikemu30
Forget eco. Try normal or sport.
