Problem Installing New Power Liftgate Struts
Old Jan 3, 2026 | 08:13 PM
NewtoRX350's Avatar
NewtoRX350
2nd gear
Default Problem Installing New Power Liftgate Struts
Just tried to install new Liftgate struts on a 2016 RX350 base model. Disassembly was a breeze, but when I tried to install the new struts they just would not fit. Gate was fully opened with both struts off, but the ball joints was about 3/4" too long. What could I be missing?
Old Jan 4, 2026 | 06:28 AM
Quantum501's Avatar
Quantum501
Are the replacements OEM or aftermarket?
ViktorG on YouTube shows the replacement for the previous generation RX....not sure if the design changed for 4th Gen but looks pretty straightforward if you have the correct replacements.
Old Jan 4, 2026 | 07:15 AM
NewtoRX350's Avatar
NewtoRX350
2nd gear
After market -- Marsflex Brand
Old Jan 4, 2026 | 07:16 AM
Bangler's Avatar
Bangler
You have to remove both before installing one. Once both are removed you can open the liftgate a few more inches to fit in the new strut.
The new struts come extended more than the normal open position allows, removing both will allow you to lift/open it the remaining bit.
Once cycled, the new strut will open to the same position as the old one, they are just shipped at max extension.
Old Jan 5, 2026 | 08:26 PM
Iko's Avatar
Iko
10th Gear
Do you have the Rx 350L? Just replaced my lift gate for 2018 rx 350 L and this is wht I bought
Amazon Amazon
I first bought the one for the Rx 350 and it was longer.
GOHRD15
Dec 21, 2024 08:36 PM
wengr
Jul 15, 2024 06:40 PM
Cal916
Aug 13, 2021 12:44 AM
sgvlex
Suspension and Brakes
Jun 5, 2017 11:01 AM
t70 supra
Nov 13, 2006 07:00 AM
