2016 rx350 oil pan
Long story short I went to change my oil and found my drain plug was cross threaded, I was able to somewhat get it all back together using JB as a temp fix but she has a small leak now
I am now researching on how to change the oil pan, I did a search on here and couldn’t find much specific to 4th gen. I found some highlander based vids that could work and one of CCN dropping the engine for a timing cover leak repair.
I am thinking of just using CCNs video to get an idea of what I’m in for with the pan itself but I just wanted to start a post incase anyone on here has gone through the motions and perhaps has a video/some tips for me before I tackle this project
As far as the part itself goes I am looking a ordering a Dorman replacement and using rtv from rock auto unless I’m guided otherwise by the knowledge members on here
Thanks in advance !
edit: I just found this video from 1A for a Camry, is it safe for me to assume it’s the same process as the engine codes are the same ?
Thanks in advance !
to just go one for one replacement?
I will explore this thought though and call some machine shops during the week, your idea seems like it’d save me a decent amount of coin. thanks for the input
if you have the pan off, just replace it.
you could also get a timesert kit and fix it that way, i've done a ton. did you get JBweld on the inside? that could be a problem, you don't want it breaking off and getting into the pickup tube.
ISFLexy
Jul 26, 2024 06:27 PM
oldlexusny
Aug 10, 2021 01:58 PM
swheat
Jun 29, 2009 06:52 PM
