Worn leather seat
Old Jan 22, 2025 | 05:49 AM
rnieves7's Avatar
rnieves7
4th Gear
Default Worn leather seat
I recently bought a certified 2021 RX 350 FSport from the Lexus dealer and just noticed that the red leather seat on the driver's side is worn to white in one particluar area. It's obviously from getting in and out. Has anyone had this issue? If so, does any one have ideas at to alternatives as it has just passed a 4-year warranty and it has 39K miles. I was not expecting this from a Lexus.
Old Jan 22, 2025 | 07:15 AM
Clutchless's Avatar
Clutchless
Start by checking this detailing forum sticky thread on Lexus Leather:https://www.clublexus.com/forums/aut...s-leather.html
You can also use the search feature box on the right side and type in leather as this has been asked before.
You could try a local car detail shop for ideas on what they can do for you, or a local car upholstery shop.
If a do it yourself type, you can clean and refinish the bottom cushion yourself with a kit from Leather Renew. I did this on my 2010 RX350. Be sure to also get the clear coat to protect the color coat. They have a chart to find your seat color. https://www.leatherrenew.com/product...e-leather-kits
I used the kit with the foam brushes.
Old Jan 23, 2025 | 07:26 AM
rnieves7's Avatar
rnieves7
4th Gear
Thanks for your help. I will look at that sight.
Old Jan 28, 2025 | 04:59 PM
RobbyJoe's Avatar
RobbyJoe
7th Gear
I’ve heard the F-Sports are a little more susceptible to this kind of wear since they have higher bolsters than the base models. People dragging themselves across the bolsters when getting in and out make the wear occur much faster. The larger the person, the worse it is too. I wonder if your seat was previously “repaired” and the coating didn’t hold up very well? Keep us informed on what you do to fix it! A lot of us will be in the same spot one day.
Old Mar 12, 2025 | 01:00 PM
rnieves7's Avatar
rnieves7
4th Gear
Just a catch up on what I have found out on the F Sport seats. I went to two upholstery shops and both stated that the material of the F Sport seats are very different than regular seats. The pseudo leather is bound to the foam so it's impossible to upholster. And they had no recommendations. So..... for now I am just careful getting in and out. The other solution is obviously to buy a new seat back which will set you back about $550 plus shipping.
Old Mar 13, 2025 | 04:07 AM
jcg0324's Avatar
jcg0324
I am very familiar with trim shops as a good friend of mine used to own one. Just because one turned you down, don't give up. Try a different one. These problems can be fixed if you find the right shop. Keep going and good luck.
omar33
Automotive Care & Detailing
Jan 23, 2025 08:53 AM
Tensi
Feb 5, 2023 04:12 PM
rx300mm
RX - 4th Gen (2016-2022)
17
Sep 5, 2018 06:27 AM
rayaans
Sep 13, 2015 01:51 PM
pamada4
Nov 25, 2008 03:57 AM
