Started noticing this “tocking” sound while at idle/crawling speeds. Just had this engine resealed due to a coolant leak a few weeks ago, which could be possibly related. Does your RX350 (2016-2022) sound like this?
Can you elaborate on this? What was sealed and was this done at a dealer?
Timing cover reseal. They said it’s usually oil that leaks not the coolant side. When they took it apart it was because there was not a sufficient amount of sealant around the cover. It was done at the dealer under warranty.
