Not starting - fuel gauge empty
Old Feb 24, 2023 | 05:05 PM
Raufbold's Avatar
Raufbold
2nd gear
Default Not starting - fuel gauge empty
So the fuel gauge malfunctioned - I was running low, the fuel light went on and I poured 10 liters, but the gauge didn't move. The car started ok, but after sitting for a few hours it no longer starts - it cranks, the battery is ok, but the engine just won't launch.
Not sure if fuel pump could have failed, since the symptoms seem to be more focused around the gauge (sending unit?). Also, could a faulty sending unit disable the pump (just because it thinks the tank is empty?)
Old Feb 25, 2023 | 06:40 AM
RX in NC's Avatar
RX in NC
If you ran the tank bone dry I would not be surprised if your fuel pump failed. But first things first -- check the fuel pump's fuse, and any other fuse that is associated with the system.
Old Feb 25, 2023 | 10:09 AM
salimshah's Avatar
salimshah
25 Year Member
There are number of possibilities and depending on your skill level you can check them out one by one or have a mechanic find out,
1. Your fuel gauge could still be bad ... giving you faulty reading [not likely to cause any other issues ... you have been operating like this before]
2. Fuel pump malfunction ... it can burn out when there is no fuel.
3. Junk got int the line . Very unlikely if you have been using good gas. [in US/Canada the gas storage facility are under tight regulations and junk typically does not get into the fuel]
Salim
PS: Gasoline and hot surfaces do not go along. So if you are a novice DIY, please leave the diagnosis/test to qualified shop.
Old Feb 26, 2023 | 12:37 AM
Raufbold's Avatar
Raufbold
2nd gear
well, problem solved - I reset the gauge by disconnecting the battery for an hour. The automatics probably thought the tank was empty and blocked the fuel pump from initiating. Resetting did the job
razgs300
Jul 19, 2021 11:51 AM
Modenaro
Nov 6, 2019 09:32 AM
nitrotang
Jul 25, 2019 08:52 PM
moshlub
Aug 4, 2005 06:11 PM
