Cost for 90K maintenance
Old Sep 11, 2019 | 08:31 AM
MellonC00's Avatar
MellonC00
Default Cost for 90K maintenance
Just got the 90K maintenance done. Cost reasonable? Did I miss anything?
stuff required:
oil and filter change
engine air filter change
front transaxle fluid drain and fill
brake fluid flush
cabin air filter change
rotated tires (over 50% remaining on tread)
checked brake pad thickness - 60% remaining (hybrid car)
Checked 12 volt battery health (perfect condition)
Total was $344.
Stuff not required:
Redline engine cleaner $15
4 new bolts on the wheels $16 -
got rid of the stupid wheel locks (who wants to steal my lexus oem wheels?) no more wheel lock keys to carry around.
Archoil Engine Oil Additive - 1/4 of $44 bottle cost. - Complete placebo effect I kind of enjoy
Old Sep 11, 2019 | 10:59 AM
RX in NC's Avatar
RX in NC
I consider all of those tasks to be DIY and will indeed do it myself when the time comes.
Old Sep 11, 2019 | 12:29 PM
mandyfig's Avatar
mandyfig
Was this a Lexus dealership? How long did they perform the service? Or were you given a loaner?
Old Sep 11, 2019 | 04:38 PM
Clutchless's Avatar
Clutchless
That is a reasonable cost for a Lexus dealer to perform those tasks. You got a lot done for a lot less than the dealers around here would charge!
I would consider throwing a bottle of Techron fuel system cleaner in the gas tank, but you can buy that stuff at any auto parts store.
I trust they checked for codes and the status of the hybrid battery.
Besides checking the pads, they should have cleaned and lubricated the caliper guide pins which are often overlooked and as the lubricant dries up can make your caliper stick, cause vibrations and even cause frozen calipers. I had one so frozen I had to replace the caliper base as it could not be removed.
It is at 100,000 that your coolants need changing, both engine and hybrid cooling system.
Old Sep 13, 2019 | 11:27 AM
MellonC00's Avatar
MellonC00
I didn't clarify. It was done by an indy shop.
Old Oct 17, 2019 | 05:58 PM
2008M3's Avatar
2008M3
Default 90K mile service question
Hey guys,
I got a 2010 Lexus RX350 AWD with 90K miles
Should I do the following:
1. transfer case
2. differential
3. transmission
4. brake fluid
5. coolant
6. spark plugs
7. oil change
8. cabin filter
9. air filter
How much should this cost at an independent mechanic? At a toyota dealership?
Thanks in advance
Old Oct 18, 2019 | 08:40 AM
salimshah's Avatar
salimshah
25 Year Member
Please look at the thin [in the set] service and warranty manual for the recommended service items. If the vehicel has been under Lexus care, they would have followed the recommended procedure. Owner has the option to skip/defer/ignore/improve/over_achieve etc. [Please read up the discussion on transmission/differential as opinions vary. Read and make your own choice].
Cost differs from region to region and based on which fluids you use, they can differ drastically. Best suggestion I can make is simply pick up the phone and call Lexus service dept and get a ball park number over the phone.
Salim
Old Oct 18, 2019 | 09:19 AM
RX in NC's Avatar
RX in NC
Or find a good Toyota/Lexus indie shop if you cannot do the work yourself.
Old Oct 20, 2019 | 12:40 PM
MellonC00's Avatar
MellonC00
the first coolant change, I think, is at 100K. Also the spark plugs come up ta 120K.
Old Jun 13, 2022 | 01:31 AM
lamar411's Avatar
lamar411
Default 90k mile service interval
Hi all,
Our 2013 RX is finally at 90k miles. I am trying to plan out the upcoming service but I see different opinions between the manual/forum. I was definitely going to do:
oil change
tire rotation
brake fluid flush
what I am not sure about is rear differential/transfer case. the manual only recommends it to be changed for "severe" driving, which is the exact opposite of the life my RX lives. I will be taking it to my local shop so price is not really a huge factor but I also don't want to do it unless it is really "necessary." What do you guys think? Important to do now at 90k, wait till later, or skip completely? Thanks!
Old Jun 13, 2022 | 03:53 AM
RX in NC's Avatar
RX in NC
Fresh fluid is always a good idea as long as the job is done properly with the correct fluid. And believe it or not, most vehicles qualify for the "severe" driving category due primarily to the amount of time spent in stop-and-go traffic.
Old Jun 13, 2022 | 09:23 AM
StingerGT's Avatar
StingerGT
4th Gear
That's a great price considering what was done. I'm at 108k miles and will likely go in at 110k to get an inspection done. I'm glad Lexus has their reports on previous history regarding maintenance.
Old Feb 26, 2023 | 06:21 AM
aviatorash's Avatar
aviatorash
Default 2013 RX350(F-Sport) - 90k service
Hi Guys - Had a quick question - My car is due for 90k service and i wanted to check what all essential items i should do in the service.
1. My vehicle has only had regular oil changes and only front brake pads replacement so what all things i should do? 60k service lists quite a few things(spark plugs etc) which i never replaced so was wondering if that is necessary.
Car runs great.
Also i am in the Austin area and was wondering if you guys could suggest a reliable mechanic as i want to avoid the dealer.
Thanks,
Aviatorash
Old Feb 26, 2023 | 07:26 AM
Clutchless's Avatar
Clutchless
Here is an older thread on this exact subject which discusses things to be performed at the 90K service.
Spark plugs are good for at least 120,000 miles. That is when Lexus says to change them. Others have gone longer with no ill effect and found they looked good at 150,000.
I recommend changing the transmission fluid along with all the stuff listed in the link.
​​​​​​https://www.clublexus.com/forums/rx-...intenance.html
Old Feb 26, 2023 | 07:31 AM
Clutchless's Avatar
Clutchless
Here are 8 shops around Austin that work on Toyota/Lexus with great ratings from the CarTalk radio show listeners mechanics files. One is a dealer so ignore that one, the rest independents. Cross check them on Google/Yelp for more current ratings.
https://www.cartalk.com/mechanics-files/search?keyword=&field_makes_tid=53359&city=austin&state=TX&radius%5Bsearch_units%5D=mile&radius%5Bpostal_code%5D=&radius%5Bsearch_distance%5D=10&sort_order=ASC
8 Results
Sort by:
NameRating
Bluebonnet Auto Repair
  • 4.7 of 5 stars
2129 Goodrich Ave, Austin, TX 78704
(512) 445-5566
View details
Red McCombs Toyota
  • 4.1 of 5 stars
8333 W IH 10, Austin, TX
(210) 357-1600
View details
Japanese Auto Tech
  • 4.6 of 5 stars
9804 Beck Cir, Austin, TX 78758
(512) 339-9239
View details
Nippon Motorworks
  • 4.9 of 5 stars
5350 W Highway 290, Austin, TX 78735
(512) 892-6224
View details
Ian Somervill's Grand Imports
  • 4.8 of 5 stars
15705 Connie Street, Austin, TX 78728
(512) 733-5399
View details
An Honest Mechanic
  • 4.6 of 5 stars
121 Pickle Rd, #A, Austin, TX 78704
(512) 462-1989
View details
dserban
Dec 8, 2013 07:37 PM
nmoulin
May 17, 2010 06:42 PM
ES3
Aug 6, 2008 08:16 AM
cm09578
Apr 3, 2008 09:35 AM
UncivilizedAMD
Mar 26, 2005 08:11 PM
