Timing chain problem
Old Nov 23, 2022 | 12:08 AM
stamy74's Avatar
stamy74
Default Timing chain problem
I have a 2010 Lexus RX450H with 210K km on board. Bought the car as second hand with 180K km couple of years ago. Car had been serviced in Lexus authorized dealer, so all services were done properly. Myself I change oil and filters every 10K km.
Couple of weeks ago I saw the check engine light on. I went to the Lexus authorized repair center where I normally take the car for service, they put the testers and they found out that there is problem with timing chain and it needs to be replaced. I have noticed that engine sometimes makes some rattling noises when it starts but it doesn't do it often though. The guys there reset the check engine light and is off now.
My questions are:
1. Is it normal such problem to appear in a Lexus and in one that has been serviced properly?
2. How urgent might be to replace the timing chain? Can the car still run for a couple of months or I might cause bigger problem to the engine? Repair is pretty expensive, around 2.5K Euro where I live.
Old Nov 23, 2022 | 04:05 AM
RX in NC's Avatar
RX in NC
Timing chain issues on these vehicles are extremely rare unless it has been abused (they are not sports cars). I would seek a second opinion elsewhere.
Old Nov 23, 2022 | 04:16 AM
Clutchless's Avatar
Clutchless
I agree with RX in NC. Nobody else here has had a timing chain issue. The start up rattle is not uncommon on these vehicles and many have complained about it but it will not affect the life of the engine.
Get a second opinion. Find exactly what code came up when they scanned it to see what caused the check engine light to appear. Let us know what that said.
These engines are very common in many different Toyota and Lexus vehicles. You do not need to go to the dealer for repairs. They often lie and recommend repairs that are not needed because the service writers work on commission and often recommend repairs that cost more than the car is worth. You need an independent shop, especially one that works on a lot of Toyotas. I doubt there is anything wrong with the timing chain.
Old Nov 23, 2022 | 06:42 AM
afpj's Avatar
afpj
That morning first start rattle could easily be the vvt system. A well known issue that is more "cosmetic" from an auditory standpoint than of any true concern. Lots of youtube vids on that.
agree with others....get a second opinion. I have not seen anyone posting about a timing chain issue.
Old Nov 23, 2022 | 07:05 AM
carguy75's Avatar
carguy75
My questions are:
Timing chain failure is rare in the Toyota 3.5 engines, but a failure could occur if the oil was not changed properly. Many people claim their cars were perfectly maintained before engine failures and sometimes that was not the case. An oil change here and there was skipped or postponed to a later time. Running engine oil for too long can cause timing components to fail even just once.
A bad timing chain can ruin the entire engine if the chain jump a tooth on the timing sprocket; especially at higher rpms. So fix the issue ASAP.
Old Nov 23, 2022 | 07:47 AM
salimshah's Avatar
salimshah
25 Year Member
Probability is a good science, but it also is a science of odds. Decisions should be based on expert opinion [which can be inaccurate too]. Then you need to look at the consequence of failing to ignore a given advice. At idle, you will have minimum [can still be high] but at high rpms and load the result can be catastrophic.
[Speculation] I seriously doubt that the conclusion from the shop is based on actually examining the chain and the train [any one or multiple things can be bad]. It most likely is based on timing of the cams information and sounds.
You can try second opinion but then your mind will keep you restless as which of the two different opinions is right [risk/cost/trust will be at play].
At the end I would say nothing lasts for ever. All mechanical things wear out. Although Lexus/Toyota use good engineering practice to select parts, but once in a while the part can be an outlier on the short life span. If I am not mistaken you are around 3x the warrantee milage.
Salim
Old Nov 23, 2022 | 07:53 AM
stamy74's Avatar
stamy74
[Speculation] I seriously doubt that the conclusion from the shop is based on actually examining the belt and the train [any one or multiple things can be bad]. It most likely is based on timing of the cams information and sounds.
Salim
Actually the check engine light went on right after I had to accelerate a bit hard to overpass someone. I will check also elsewhere and see the codes. I am 100% sure that the car has been maintained properly. It had full service history in Lexus when I bought it (I also did an extensive check to make sure that everything works fine) and I also never missed an oil-filter change.
Old Nov 25, 2022 | 12:19 AM
WolfyLS460's Avatar
WolfyLS460
For what it's worth, my old Gen 2 RX400h Hybrid that I just sold also had bad timing chain and high mileage. Cost $900 to repair. Later on it developed hybrid motor issues and the check engine light would come on intermittently. I drove like an old lady and never abused the car, so I'm thinking the problem might be specific to the hybrid RX's.
One day, the engine overheated while cruising on the freeway, leaving me stranded in a bad part of town. I quickly sold the RX400h and bought a newer Non-Hybrid RX for a peace of mind. The savings in gas don't justify the high cost of repairs when (not if) the hybrid parts do go bad.
Old Mar 15, 2023 | 06:59 PM
stamy74's Avatar
stamy74
So the problem was finally related to the catalytic converter. The engine light appears sporadically and switches off by itself in a few days. Timing chain was checked, no problem at all with it.
Still an expensive repair though, about half the price of distribution system.
Old Mar 20, 2023 | 09:27 AM
laserwiz's Avatar
laserwiz
Half the price of the distribution system? What's that? Did they replace the catalytic converter? If so, how much was that?
You may want to check out this video re: oil change frequency.
ctrujil24
RX - 3rd Gen (2010-2015)
Nov 14, 2017 09:12 AM
flexkavana
Aug 24, 2017 01:23 PM
MysteryFan
12
Feb 17, 2011 11:16 PM
MorePower
Sep 30, 2008 09:08 PM
carcass66
May 12, 2004 05:37 AM
