2011 Rx350 climate error
Old Aug 24, 2022 | 05:35 PM
Rellik876's Avatar
Rellik876
2nd gear
Default 2011 Rx350 climate error
Has anyone had a climate control system error pop up once it started raining?
If YES how did you fix this issue?
Thanks in advance.
Old Aug 26, 2022 | 05:10 AM
Clutchless's Avatar
Clutchless
Make sure your sunroof drain tubes are clear and not clogged which could lead to interior water leaks. Check the carpet up front under the dash to see if it is wet or if anything under the dash is wet. There are youtube videos showing how to clean the drain tubes with weed wacker line. Some shops use compressed air.
Or your A/C drain tube could be clogged and should also be checked and cleared the same way. It is easier to reach from under the car.
rxsuperman
RX - 3rd Gen (2010-2015)
16
Jul 7, 2017 06:16 AM
JimK2
Dec 24, 2015 12:15 PM
Lexi66
Feb 7, 2014 01:06 PM
Mar 10, 2011 02:17 PM
