Upgrade soundsystem
Old Nov 20, 2021 | 08:40 AM
ptrustfull's Avatar
ptrustfull
Default Upgrade soundsystem
Hello, i have a 2013 RX450h and want to upgrade the soundsystem. Want to start with adding an amp to the 9 speaker factory system. I would like to know if the radio has a 4 channel output that goes into the amp and that the amp powers the 9 speakers seperatly. I had this in my BMW e46 with Harman Kardon system. The amp is more like a crossover for the 11 speaker. In that case i put my amp between the headunit and amp. I want to know if i can use this method on the RX.
Old Nov 21, 2021 | 04:44 AM
Clutchless's Avatar
Clutchless
Try some searching as this has been asked about and discussed more than a few times. Just use simple terms like amplifier, or audio
You may also want to look at the audio forum
​​​​​​https://www.clublexus.com/forums/lex...lectronics-12/
See what Crutchfield says will fit as they do the research and sell a lot of stuff https://www.crutchfield.com/S-GARLaVFEOPZ/
The best for last, see what this guy installed in his 2013 RX
https://www.clublexus.com/forums/rx-...installed.html
Old Nov 21, 2021 | 08:00 PM
happy1977's Avatar
happy1977
I replaced ours 2011 RX 350 with these:
Focal 165 V30 (2 pairs front)
Focal 165 A1 (2 pairs rear)
ARC10 sub
ARC KS300.4
JL JX500
JL Audio CL441dsp.
The only down side is I lost the built-in bluetooth connection but I bought an external bluetooth connector and plugged it on the aux.
Old Nov 22, 2021 | 02:28 PM
salimshah's Avatar
salimshah
25 Year Member
ARC10 sub
ARC KS300.4
JL JX500
JL Audio CL441dsp.
Speaker swaps are theoretically easy swaps, but when an active component is replaced a lot more needs to be investigated. Are signal levels in 3rd gen RX standard? First gen and other Lexus models [the ones I have dealt with] have non standard signals .... dual differential [l+, l-, r+, r- (where - are not ground)] and the amplitude is almost twice. Also the communication between active components is thru a serial communication link. Please share your findings.
Salim
silversprucesc3
Jul 4, 2004 09:43 PM
SC2jz
Sep 30, 2003 12:32 PM
