Mirror tap radar detector connections
Hey gang. I’ve got a radar detector I’m wiring under the rear view mirror. It’s made by Blendmount. They’ve got a mirror tap kit, but I’m having trouble finding the ground wire and 12v on with ignition/car running wire. Wondering if any of you have done this mod or maybe have the wiring diagram for the mirror electrical from the svc manual? I’d still need to make sense of it if you had the diagram but at least that’s a start. I found two wires/ports that were powered with key off and start position, but when I turned the car on both lost power with it running, which I thought was odd.
Right now I’ve checked all the ports on the bottom/easily accessible row of ports on that connector block. The upper row is gonna be tough bc the wires coming out of the harness plug run right upwards to the roof, which of course covers the ports pretty well. Can’t seem to pull any slack from the roof on the wires either. If you have ideas on this too I’d love to hear ‘em.
Try the $20 short term subscription to The Toyota Information System (TIS) online. https://techinfo.toyota.com/techInfo...tis&_nfpb=true
It will have your wiring diagrams, or take it to a custom shop that does these installations
Sounds like 2010 may be different but I used this method with an Invisicord on our 2015.
https://www.clublexus.com/forums/rx-...rror-pics.html
Here's a post from a 2010 owner:
https://www.clublexus.com/forums/rx-...010-rx350.html
Tip: if any web site's search feature doesn't work for you then try a site restricted Google search. Even though I previously used the first thread I never bookmarked it or anything. To search this forum you'd search using keywords and site:www.clublexus.com/forums/rx-3rd-gen-2010-2015. For example, I used these in my search and quickly found both of the above links:
Code:
hard wire mirror site:www.clublexus.com/forums/rx-3rd-gen-2010-2015
cosxp
09-27-23 02:06 PM
LewisLou
06-29-23 11:57 AM
b00st3
05-24-14 08:44 PM
