Seat heat and filling switch
7th Gear
Good morning fellows!
Last night I purchased a 2010 RX350 FWD to replace my 99’, which I will be giving to my son, but noticed that the whole switch is not working. The leds for both heating and cooling are not working.
I have googled and read threads, but need help here.
To start, where is the location to the fuse that controls the rotating switch?
Edwin
Edwin
Check fuse box under driver side of dash. Inside of cover states which fuse covers what item. You must lay on your back and look up with a flashlight. It is about 5 inches long and 2 inches wide, a black box. This has failed on the HS250h forum or CT200h forum and they just replaced the switch. I think the secton can be removed from the console. YOu can probably get in below it if you remove the upper box in the center console compartment as there is a much larger area below it that goes forward. Also serves as a great hiding place.
ItsAlive
03-16-15 08:58 AM
