Advice needed!
Planning to buy an RX for my wife 2010-2012/60-80k miles
My questions are:
*RX350 vs RX450h
Does the hybrid engine save that much on MPG? Or saving's not worth over engine issues that might happen at this mileage?
*What do i expect from the car at this mileage? What do i need to check on the first place before buying it? Brakes, suspension? Any other compartments?
*Does it worth buying a car at this mileage? It's a "known fact" that Lexus engine can live long, is it?
*I'm placing RX350 over RX450h, but would like to hear your oppinion
Any other experience, bad/good with this models at this year or/and mileage is welcome!
Thanks
Hybrid power train is VERY reliable. That's why hybrid sections here and at say toyotanation are so lame. Not much going wrong.
Why then I rid of my Highlander? Unfortunately, it landed with two accidents in two months, and I am very superstitious.. I don't like driving cars sending me warnings. Plus, it developed absolutely weird shake rolling at speeds between 25 - 35 mph. Very annoying. But I saw only 2 or 3 reposts of similar problem, so it's rather odd. That's why I pulled the plug. Otherwise, great car. Great hybrid power train.
My questions are:
*RX350 vs RX450h
Thanks
But if you live in city and drive mostly in stop and go traffic, the mpg savings and the reduced brake wear because of teh regenerative braking system may be worth it.
And yes Lexus engines can live for a very long time and are bulletproof maintenance wise. Parts are cheap since they share a lot with the Toyotas
Driving characteristics are a bit different. No transmission shifting on hybrid so acceleration is more like a power boat, and tends to be a bit smoother, but some traditionalists prefer feeling and hearing transmission shifts. Braking a little difference because there are small but detectable transitions from regenerative to mechanical braking. Some don't like the subtle but audible generator whine during regenerative braking.
When vehicles roll off assembly line, they tend to fall with-in a spread from each other. As they are used they start becoming 'individual machines" .. based on care and usage. All used 350s will not be the same and all used 450Hs will not be the same. I would test each and determine if that vehicle is what you like. When you test, try to test in the environment that you would drive it. With a few weekends invested, you can figure out the prevailing prices and condition and models. Dont forget to check out the FWD and AWD models too. By that time set the median price you are willing to pay and jump when the right vehicle comes your way. All this helps when you are not in a desperate situation where you needed a vehicle yesterday.
During evening hours you can browse CL to see what owners have to say about the brand and model. Also never buy without knowing the history of the vehicle.
Salim
Premium gas gives a touch more power but you'll never notice the difference. It's for the brochure specs. The engine will be perfectly happy on regular.
The mpg savings with the RX450h will take something in the orders of 12 years plus to break even for the average driver.
We bought the RX450h vs the RX350 for reasons other than mpg. We liked the firmer ride and the refined quiteness of the RX450h better vs the RX350.
My questions are:
*RX350 vs RX450h
Thanks
