Tire balancing
Old Jun 10, 2018 | 04:01 PM
johnt3's Avatar
johnt3
5th Gear
Default Tire balancing
As I do research leading up to my tire replacement, I have another question. I assume balancing was just balancing, but I have came across " road force" balancing. Anyone here use that type of balancing? I wonder what the dealership uses?
thanks again
Old Jun 11, 2018 | 06:53 AM
kezgao's Avatar
kezgao
The dealer here as access to both technology. If you just ask for balancing, they'll use the typical spinning balancer.
the normal balancing here costs about $50, the road force balancing costs $130. Normal balancing for me does the trick. Road Force is typically used to if there is still vibration after the spinning balancing (to confirm defective tires or imperfection in the tire itself). Also I think they recommend it for low profile tires. Minor imperfections in these tires will be greatly felt. The side wall on the 18 or 19 inch rims on an RX are big enough that the spinners will be just fine for. No need to ask for the expensive road force unless you still feel vibration after the tire balancing.
Old Jun 11, 2018 | 04:27 PM
ukrkoz's Avatar
ukrkoz
You have regular balancing, road force balancing and on car balancing. For the first two, wheel is removed from the vehicle, for the third - it's done on vehicle. There's special old timer machine for this.
Local to me Discount Tire does not charge extra for road force. Same price.
Normally, there is no need for those odd balancing techniques. In case you just can't get them balanced, with tire being known to be clean inside and have no manufacturer defect, on car balancing is the way.
Old Jun 11, 2018 | 10:06 PM
lexusrus's Avatar
lexusrus
Agree with ukrkoz.
Usually on the RX road force balance is not needed UNLESS you feel vibrations.
But if you have low profile tires as found in RCF, then road force balance is recommended.
eaglefox12
NX - 1st Gen (2015-2021)
Nov 12, 2017 11:48 AM
Steve2424
Oct 24, 2014 04:33 PM
RG3toDC
May 12, 2013 06:56 AM
sam12345
Wheels, Tires & Brakes Forum
Jan 10, 2013 09:09 PM
BananaGS
Jun 13, 2002 04:41 PM
