BSM message
Old Oct 15, 2017 | 08:37 AM
Lori4's Avatar
Lori4
Default BSM message
My 2013 Lexus 350 RX won't start. It say BSM not available. Any ideas?
Old Oct 15, 2017 | 10:57 AM
comotiger's Avatar
comotiger
Mods, please move this thread to the RX forum.
AFAIK, BSM is Blind Spot Monitor. There is no reason why a problem with that system should prevent your vehicle from starting.
When do you see the BSM message- when you push the start button? How long have you had this starting problem? Does the engine crank when you push the button? Maybe you have a weak battery. Have you tried jump-starting it? If that doesn't work, you have to get it towed to a dealer or a good indy shop for diagnosis. Good luck!
Old Jan 11, 2020 | 02:42 PM
Dchernesky's Avatar
Dchernesky
I have had this problem several times and was very frustrated. What I found is the battery is getting used and not being recharged fully. So I attached a charger to it and let it slowly recharged overnight. Once I did this and the battery was fully charged, I have not had a no start BSM error since. Give it a try!
Old Jan 11, 2020 | 03:43 PM
rababich's Avatar
rababich
Originally Posted by Dchernesky
.... What I found is the battery is getting used and not being recharged fully. So I attached a charger to it and let it slowly recharged overnight. Once I did this and the battery was fully charged, ....
What is the system voltage with the engine running at idle?
If it's not around 13.2-13.5v the alternator is not properly charging the battery.
With the engine off it should read around 12.2-12.4v.
Check the battery connections for corrosion.
Old Jan 11, 2020 | 04:03 PM
Dchernesky's Avatar
Dchernesky
thanks, the connections are just fine, no corrosion. Will have to look into charging voltage. Did not think of that.
wculbert
Aug 5, 2013 05:36 PM
randy57
RX - 1st Gen (1999-2003)
Jan 24, 2013 08:10 PM
Lookyoung
RX - 3rd Gen (2010-2015)
Jan 7, 2013 10:52 PM
StkMkt
Sep 21, 2012 11:19 AM
meZoom!
Dec 27, 2002 09:22 PM
