code P0607 n P0138 cel light with check Eng. light on. what could be a fix for this
Hopefully this will help:
P0138 is for 02 Sensor, Bank 1 Sensor 2 RH/Passenger Pipe Sensor (Downstream/Postcat/Rear Sensor)
P0607 ECM (Electronic Control Module, could be caused by P0138)
Replace
Replace
flowrider
close
- Join DateNov 2008
- LocationArizona
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:2,395 Times in 1,652 Posts
To the OP - Welcome to the site, lot's of GREAT information here. You have posted to the wrong forum. You should be posting here:
https://www.clublexus.com/forums/rx-...2010-2015-212/
Lou
Lou
Clutchless
close
- Join DateMay 2005
- LocationVA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,734 Times in 1,442 Posts
Do a little searching as this has been covered before, in both this forum and other Lexus model forums, such as the ES350. 02 sensors fail once in a while but are not that difficult or expensive to replace. However the ECM may be expensive. I would first do the O2 sensor, then hope that is all you need. There are a couple of them and if you search you will be able to find other threads and at least one with diagrams to show the location of each sensor.
salimshah
close
- Join DateApr 2001
- LocationAustin, TX
Liked:1,393 Times in 1,227 Posts
It is important to post milage and any recent work done. This will help in predicting end of life of certain products .. like sensors.
Salim
Salim
