How to Replace engine coolant (Super Long Life)?
2012 RX 100k miles. Should I replace coolant as suggested in the manual?
when car is cold the coolant level is very low in the tank. Does it go up to max when car is hot?
should I just top off coolant or get it replaced?
can I replace myself by just sucking old stuff out from the top and putting new SLLC in?
Coolant is measured when cold, so normally the coolant level should be between Low and Full lines. Yes, sometimes the fluid level rises when hot (and some cars actually provide separate lines for hot and cold readings), but in this case Lexus says measure when cold.
There is a drain valve at the bottom of the rad, you can simply drain the coolant from the rad and then fill up with new coolant. If your reservoir is pretty much empty, just fill it up too. Usually suction is used for these as they are a bit harder to drain, but since you're low already might not even have to bother, just fill.
Youtube probably has a dozen how-to videos for every model of car out there, you can probably find something helpful to show you the steps.
prtuc2
RX - 3rd Gen (2010-2015)
17
Feb 13, 2020 05:45 AM
