buying from a lexus dealer
Part of the CPO process involves doing what's known as a load test on the battery using a battery tester, I seem to recall that its called a GR8. I know that the techs attach a copy to the CPO checklist.
If memory serves, the battery has to be around 70% of capacity to pass CPO standards; most of the time when a battery "fails" the car starts up just fine.
Like most anything consumable on a CPO the standards for replacement are much higher than what you or I would do on our own cars.
Edited to add: If you want actual specifics I can find out tomorrow.
For what its worth, I bought a 2013 RX-350 CPO in February with 22K miles, and they replaced the vehicle battery during the CPO inspection. No idea why. While looking on line before the purchase, I saw several other RX's that had their battery replaced and thought that was odd.
They will do a load test and only if it fails will they replace the battery.
A lot depends on geographic location and temperature. Heat will accelerate battery degradation.
I traded in a 2012 CT200h and a 2014 Ford F-150 Lariat last year to the local Florida Lexus dealer. Neither car had any indication when I owned them that there was a battery issue yet the dealer replaced the 12 volt battery on both before putting it on their used car lot.
A battery costs $120 tops. But perception is worth a lot more. When buying a CPO, you feel like buying almost brand new. Return on Investment. You know that pissed customer will never be happy again, when one morning the engine would not crank.
velocity12
Sep 10, 2008 10:23 AM
