Differences between 2010,2011RX and 2012,2013
Old Nov 18, 2015 | 01:41 PM
Barry2522's Avatar
Barry2522
Default Differences between 2010,2011RX and 2012,2013
Thinking about trading my 04 330 for a 3rd gen RX . Are the 2012 or 13 much better than the 2010 or 11 RX . I heard the newer ones are quieter with more insulation and different glass . Is this true and is there any other things that I should consider . Thanks
Old Nov 18, 2015 | 04:43 PM
MDames2's Avatar
MDames2
The 2010 - 2012 look virtually the same. I believe the 2012 is rated for regular gas unlike the 2010 and 2011 that takes premium grade gas. The 2013 has the different grill and some other cosmetic and functional changes. I'll let others chime in about what the other changes are for the 2013. As far as being quieter, I'm not sure that would be easy to validate. My 2010 is pretty quiet and does have the dual paned laminated glass on the side door windows.. But the definition of quiet will range wildly depending on who you ask. These are great vehicles. You can't go wrong with any of those years.
Old Nov 18, 2015 | 11:35 PM
litzdog911's Avatar
litzdog911
If you haven't already, check out some of the reviews and other links in the FAQ thread here ....
https://www.clublexus.com/forums/rx-...ease-read.html
Old Nov 19, 2015 | 07:32 AM
gusar's Avatar
gusar
2013 runs on regular gas and LEDs on headlights look modern. I specifically waited to buy 2013 (used) because of better looks.
Old Nov 19, 2015 | 07:45 AM
GSteg's Avatar
GSteg
Here is a great thread outlining the between the pre- and post-facelift RX450h, which should be very similar to the RX350:
https://www.clublexus.com/forums/rx-...l-listing.html
Biggest difference would be the front facelift.
Old Nov 22, 2015 | 03:45 PM
danielxxxx's Avatar
danielxxxx
I own a 2010, and even though the owner's manual says to run on super gaz, I fill it up with less expensive regular and I haven't seen any difference. My dealer told me the sensors in the motor will detect the difference and adjust accordingly. Premium gaz is more compulsory with motors with turbocompressor, like the new NX200.
Old Nov 25, 2015 | 06:07 AM
Marqevans's Avatar
Marqevans
I had both a 2010 and 2012. One big difference for me is they added a DC outlet in the floor. The 2010 only has one buried deep inside the console.
Old Feb 10, 2023 | 06:27 AM
ljCharlie's Avatar
ljCharlie
Thank you so much for all the help, much appreciated!
HSVRX350
RX - 3rd Gen (2010-2015)
Feb 19, 2017 11:09 AM
Yurka
12
Aug 1, 2013 07:24 PM
pinipig523
Jul 15, 2013 11:22 AM
cossie1600
Oct 15, 2012 09:22 AM
