Replacing 2013 RX350's trunk light with LED
Old Oct 27, 2015 | 07:46 PM
frOregon's Avatar
frOregon
10th Gear
Default Replacing 2013 RX350's trunk light with LED
Hi there,
I am a new member here and recently purchased a certified '13 RX 350. Love it! BTW, do anyone have info (LED bulb info and ease of installation) on how to swap the trunk halogens with LED? Thanks!
Old Oct 28, 2015 | 04:18 AM
Freds430's Avatar
Freds430
Ordering these bulbs today and when received will do my wife's 2015 RX. There are two on each side and one on the hatch. Easy to remove cover with a thin putty knife. Use very little force. Once out easier to disconnect the harness than remove the silver metal housing and replace. I did my ES's trunk and what a difference in brightness.
https://www.superbrightleds.com/more...rvb/2515/5144/
Old Oct 28, 2015 | 05:05 AM
greeknasty's Avatar
greeknasty
https://www.clublexus.com/forums/rx-3rd-gen-2010-2015/736663-2010-2014-interior-lighting-led-conversion.html
Old Oct 30, 2015 | 01:09 PM
frOregon's Avatar
frOregon
10th Gear
Thanks Fred and Nasty. I ordered the bulbs (31mm size so will make a note to bend the metal) from Amazon and should arrive tomorrow.
Old Nov 4, 2015 | 07:13 PM
frOregon's Avatar
frOregon
10th Gear
I did the trunk and door lights. How do I pull the halogens from the footwell?! I can't seem to pop it off.
Old Nov 4, 2015 | 07:24 PM
greeknasty's Avatar
greeknasty
use the tabs on the side to pop out. been a while but if i remember thats what i did
Old Nov 4, 2015 | 07:51 PM
frOregon's Avatar
frOregon
10th Gear
I got the plastic cover off but can't grip and pull the bulb out. Can you elaborate on what you mean by tabs?
Old Nov 5, 2015 | 05:04 AM
greeknasty's Avatar
greeknasty
Oh the actual bulb I thought you meant cover. Hm that's odd you can't pull it out. Use a towel or something with grip and pull. Should slide right out
Old Nov 5, 2015 | 09:06 AM
tqh's Avatar
tqh
The plastic housing has two parts, maybe you haven't separated them first? They are held together by tiny plastic tabs. After they are separated, you push on one of the two the metal bulb holders and the bulb comes off.
Old Nov 5, 2015 | 02:59 PM
frOregon's Avatar
frOregon
10th Gear
Hi TQH, Would you please elaborate on what you mean by tiny plastic tabs. I just popped out the white/clear case and see the bulb.
Old Nov 5, 2015 | 10:40 PM
raylor4's Avatar
raylor4
How many ___________ does it take to change a light bulb?
Sorry. I couldn't resist.
Ray A.
Old Nov 9, 2015 | 09:45 AM
frOregon's Avatar
frOregon
10th Gear
I haven't had problems in the past changing bulbs but I can't seem to take the bulbs out from the foot well. Help!
Old Nov 9, 2015 | 03:41 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
I did what greeknasty said and used something with grip to remove the bulb. No twisting. it's been a few years since I did mine. But I remember removing the panel on the passenger side for easier access. Not on the driver side though. That took a little longer. It's possible. Don't give up.
Old Nov 9, 2015 | 08:06 PM
frOregon's Avatar
frOregon
10th Gear
Hi Kitlz and greeknasty.
I appreciate your help. I finally got it replaced with LEDs on both foot well! It looks great!
Old Jul 1, 2017 | 09:40 PM
Alfa777z's Avatar
Alfa777z
Hi frOregon. I'm glad you did it. Could you please specify what did you mean by footwell? Is it a stepwell bulb from under the mirror or at the bottom of the doors?
Thanks.
Sep 29, 2018 01:37 PM
bmwlexus09
Jan 4, 2017 04:47 PM
CrackerJac
Jan 9, 2016 11:07 PM
VanCityLS4
May 21, 2015 10:37 AM
kenforum
Jan 8, 2014 01:32 PM
