Blue Tooth Sync
I use Tune-in Radio to pull in stations to my Android and stream them via BT to my 2011 Rx radio. I am always asked to reconnect after each restart. Have to go into setup every time to resynch BT to Multimedia. Is this normal? I should think that as long as BT is open on my phone and the two have already been synched that I should not have to reconnect. It's a pain!
Go to menu-setup-audio-bluetooth audio- check auto bluetooth sonnect on, then save
also
go back to audio settings-select portable player-portable player info- connection method- change it to From Vechicle
now ur phone should connect and play automatically once the vechicle and phone establish connection.
Also make sure your phone is set to auto connect with the bluetooth on you car.
also
eugenez
NX - 1st Gen (2015-2021)
May 27, 2016 09:11 PM
