Power Tailgate Noise
Old May 10, 2013 | 01:03 AM
satnav's Avatar
satnav
Default Power Tailgate Noise
Hey all maybe I am paranoid, but recently I pushed power close button on the lift gate and a family member then also pushed the lift gate shut. Is it possible that the lift gate is broken now? It seems to work fine, but if I listen carefully I can hear some what seems to be grinding noises at the very top. Do the other RX power tailgates make a consistent sound throughout the open and close process.
Old May 10, 2013 | 04:38 AM
DunWkg's Avatar
DunWkg
Wow, off all the tests I've done on the lift gate, that is one I hadn't done. I'll give it a try and tell you what I think.
I'm actually surprised your family member was able to close it while it was already in motion. Thinking that may have been a bad thing.
Old May 10, 2013 | 06:28 PM
DunWkg's Avatar
DunWkg
I tested today and my initial opinion is confirmed....manually closing an auto closing lift gate may create damage. The door really resisted my efforts to close it as it was closing. Your family member must have really forced it to get it to close.
I might suggest having a dealership check it out for possible damage, especially if you hear a grinding noise.
Good luck,
Old May 11, 2013 | 05:04 AM
BertL's Avatar
BertL
OP, I also suggest you take your RX into your dealer.
I would offer that you carefully consider your words describing the problem when you take it in. Page 93 & 94 of the 2013 RX350 Owners Manual have two warnings in this regard:
To prevent back door closer malfunction
●Do not apply excessive force to the back door while the back door closer is operating.
To prevent damage to the power back door
●Do not apply excessive force to the back door while the power back door is operating.
Good luck!
Old May 13, 2013 | 02:02 AM
satnav's Avatar
satnav
Thanks all I think I am going to take it to the dealer. Hopefully no damage I will let you guys know.
Old May 13, 2013 | 05:47 AM
vlad_a's Avatar
vlad_a
I accidentally tested what would happen if an object prevented the door from closing. I had too much groceries in the trunk and a carton of milk got in the way. The door started clicking, then made a double-beep and disengaged. So, it looks like if a certain force is exceeded, there is a fail-safe to unload motor's power to prevent damage.
Old May 13, 2013 | 10:37 AM
rxsuperman's Avatar
rxsuperman
I think the issue is pushing down on a closing hatch or lifting up on an opening hatch rather than pushing down on an opening hatch or lifting up on a closing hatch.
Tmymck
NX - 1st Gen (2015-2021)
Apr 24, 2017 10:42 AM
clickart
RX - 4th Gen (2016-2022)
34
Apr 6, 2016 07:33 AM
boatable
Jun 30, 2013 03:25 PM
umpalumpa
May 2, 2006 04:53 PM
K-Bud
GX - 1st Gen (2003-2009)
Jan 12, 2006 03:57 PM
